03-28-2009, 11:54 AM | #1 |
Replacing a Cab VIN Question...
Let's say one was to replace their cab with one in much better condition. Since the VIN plate is on the cab, and assuming the replacement cab didn't have a title, what would you do as far as the title is concerned? Is it legal to swap the VIN plate from the bad titled cab to the non titled replacement cab? If not, what would one do in this situation?
Thanks in advance for any info and thanks for this great forum.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" |
03-28-2009, 12:07 PM | #2 |
Re: Replacing a Cab VIN Question...
There are a couple different ways to do this.
1) Call your DMV. Chances are they will issue you a new VIN tag after the swap. They will check the VINs on the old cab and new cab to make sure everything is clear. 2) Swap your old VIN to the new cab using the rosette syle rivets. Is it legal? No. If the police figure out what you did will you get into trouble? Yes. How will they figure it out? I don't know. If you choose this one you maybe shouldn't post exactly what you did on the internet.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-28-2009, 12:09 PM | #3 | |
03-28-2009, 12:53 PM | #4 |
Swap it.
03-28-2009, 04:39 PM | #5 |
Its done all the time. It only makes sense to use the better parts. If you have a better cab use it.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 03-28-2009 at 04:40 PM. |
03-29-2009, 01:03 AM | #6 |
60-66 Nut
Contacting your state vehicle inspector is probably the correct and legal way to do it, so they can issue a new VIN for it. However be prepared to have all the requested documentation for your purchase for every single part you are building your truck with. Even then there is no guarantee that you will get a new VIN. The inspector may see something he or she doesn't like and refuse to issue a new VIN for your truck......could be they're just having a bad day. At least that's been the way it works around here.
03-29-2009, 10:06 AM | #7 |
1966 Crew Cab & 4X4 Fanatic
Here in Arizona, if you do it legally they will issue you a salvaged title making your truck worthless IMO. If you do it illegally and are caught this can look like it was stolen to law enforcement agencies. Tough choice??
03-29-2009, 10:10 AM | #8 |
Lowered in Cleveland
When I bought my truck I had no Id Tags in my truck, both were gone, so I bought a vin tag that they use in the hot rods at my work and hammered in the vin and took it back to the inspection and had no problems.
03-29-2009, 02:02 PM | #9 |
Resistance is Futile
I would not tell anybody anything.....its just the way you bought it..get it?? What someone doesnt know isnt going to hurt them in this case....I would do it without hesitation.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-29-2009, 02:14 PM | #10 |
Install the new VIN tag on the cab in the correct location and take the title and truck to your local DMV for inspection. If questioned, the VIN tag was removed during the restoration process, to preserve it and reinstalled upon completion.
03-29-2009, 02:45 PM | #11 |
Ditto, plus were talking about an over 40 year old truck.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
03-29-2009, 11:41 PM | #12 |
I guess the first thing to ask is do you presently have a tittle to any of the above vehicles/Cabs registered in your name already? If not go do it. Then swap the cabs. If you already have it registered in your name then all you have to do is swap out the cabs and vin tags. Remember to use the correct rivets.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 03-29-2009 at 11:42 PM. |
03-30-2009, 01:15 AM | #13 | |
I've got other priorities, but I'm quickly running out of things to do besides fix my cab or swap. I'm down to bodywork/paint and interior. Besides the cab, the worst part of the truck is the lower doors and the're fixed easily and cheaply enough. Aside from the cab, bodywork/paint is just taking it down to metal and then spraying. So now I just have to decide is it worth it to fix my cab or would it be better to swap. The decision would be a whole lot easier if one were to come up locally for a good price.
