Old 03-28-2009, 02:16 PM   #1
69lemans
Consoles?
Here is a mock up of a console I want to fabricate so I can add cupholders and a modern radio without cutting up the dash. Question: if I put vents in the side,would that alone allow enough floor heat to pass thru,or do you think I would have to run flex hose to each vent?
Any body else have pictures of consoles you've installed?
69lemans is offline   Reply With Quote
Old 03-28-2009, 02:20 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Consoles?
That looks like a great mock-up. I would think that vents would allow enough heat to pass thru without having to run flexhose to them.
leddzepp is offline   Reply With Quote
Old 03-28-2009, 02:35 PM   #3
Andy4639
Old member
Andy4639's Avatar
Re: Consoles?
Looks darn good to me. I would run hoses and buy some vents out of a later model truck to direct the heat where you want it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-28-2009, 03:32 PM   #4
38chevyhotrod
38chevyhotrod's Avatar
Re: Consoles?
I have a console in my suburban, and do not use hoses.
I think it is better to use hoses because otherwise your whole console will heat up and also the rest of your dash, I think i am going to use hoses later on.
The problem is, you probably have 4 outputs.
1 on each side and 1 in the front which directs the air to both sides.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 03-28-2009, 03:38 PM   #5
Highsteel
Chasin' the Dream
Highsteel's Avatar
Re: Consoles?
I agree! I have a a little kaddie thing on the floor for cd's, coinage, and drinks. Nothing like blowing a bunch of hot air on your cold drinks!
Born with a Bowtie
1971 C/10 350/350 Daily Driver/project
Assumption=The mother of all -ups
Highsteel is offline   Reply With Quote
Old 03-28-2009, 04:01 PM   #6
killer71
killer71's Avatar
Re: Consoles?
I would run the hose personally...btw that mock up sure is making me hungry...Got Milk!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 03-28-2009, 05:15 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Consoles?
Try using some PVC pipe and elbows to make it more rigid.
piecesparts is offline   Reply With Quote
Old 03-28-2009, 05:28 PM   #8
westofb
I really hate wet sanding!
westofb's Avatar
Re: Consoles?
I never saw a custom "raisin bran" console before.
westofb is offline   Reply With Quote
