Old 12-20-2002, 03:14 PM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Will 305-50-15 fit ok on my.......
......15 X 8 4x4 ralleys? I want a big beefy tire on the back. Anyone wouldn't happen to have any of these on their truck at stock height?
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 12-20-2002, 04:31 PM   #2
Ackattack
Ackattack's Avatar
I wouldn't put that wide on a 8" rim. Maybe on a 10"
Ackattack is offline   Reply With Quote
Old 12-20-2002, 04:59 PM   #3
crazy longhorn
Fabricate till you "puke"
I agree with Ackattack......they should be on 10" wheels. You can run a 275/60/15 on an 8" wheel.....they are crowdin the wheel a bit, but not too bad. I get a full footprint on mine when I kick to throttle
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-20-2002, 06:00 PM   #4
Zumo
Hot Rods For Life
Zumo's Avatar
I once put a 305-50-15 on a 15 X 8 Cragar street star and it seem to work fine. I was on a 1969 Pontiac LeMans. It rubs on dips but other then that they worked great.
Andy
Old 12-20-2002, 06:22 PM   #5
cableguy0
i agree with crazy i wouldnt go no bigger than a 275 on an 8 inch wheel at least if u plan of having the tire stay on the wheel
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-21-2002, 01:02 AM   #6
Ron's68
Ron's68's Avatar
I have a 295/50/15 on 10" rims. I don't think I would put a larger wheel on. These come out to the very edge of the wheel well.
68 LWB, .040 over 350 with 10:1 pistons, balanced, vortec heads,comp 270H cam, air gap RPM manifold, holley 750, 4.10 posi and gear drive to annoy the neighbors.
Ron's68 is offline   Reply With Quote
Old 12-21-2002, 01:08 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would want a 10 inch rim ant the least for rubber that wide. If you run them they will wear in the center pretty bad.
Old 12-21-2002, 09:36 AM   #8
I have 275/60 on 8" ralleys, and on my step they fill the wells. I have stock springs, so I don't fear any rubbing (especially since all the parts are off at this moment). I would think if you was lowered at all or did any hauling, they would rub. Plus like Andy said, I would think the would bulge a lot in the middle and wera out fast. Local tire shop specs recommend 10" minimum for that size for what it is worth.
Old 12-21-2002, 10:19 AM   #9
67/72junkie
tire size
I have 295-50-15 on back of 69 mounted on 10s . They will occasionally rub on the inside of tub under hard corner.Have not had this problem with 71 or 72 but 5 lug has a wider rear.I personally wouldn't run anything bigger than a 275-6o on 15x8
67/72junkie is offline   Reply With Quote
Old 09-16-2012, 01:08 PM   #10
Tyler H
Re: Will 305-50-15 fit ok on my.......
I had 275 60s on 15x8 and now the center tread on my bfg's are smooth, but they're on 15x10s now so i dont have to worry about it getting worse.
Tyler H is offline   Reply With Quote
Old 09-16-2012, 02:04 PM   #11
CG
BlahBlahBlah
This might be a record ... An answer to a nearly 10 year old thread =)
Welcome to the board Tyler H
Old 09-16-2012, 06:05 PM   #12
Tyler H
ha. didn't even realize that.. thanks haha.
