Front Brake Line Hell
Hey all,
Can you give me some advice on removal of the front brake lines? I am working on the 78 Jimmy and doing a full brake job. The lines were rotted out. I got the hardline off the rubber line on the passenger side but am struggling on the drivers side, I also need to know how to get it off the frame. The new ones have a clip on them to hold them on but I don't see the clip on the existing ones, however it is tight and a little dark. Any guidance would be greatly appreciated! Kind Regards, Scott |
Re: Front Brake Line Hell
On the existong ones, instead of a clip, there's a sheetmetal nut that holds it on. You have to screw it off. I feel ya man, for some reason front brake lines at the frame are IMO the hardest thing to get off of the whole truck.
I just did a complete brake job-master, lines to the combo valve, lines out of the combo valve to the hoses, hoses, calipers, rear lines, rear hose, rear lines to the cylinders, cylinders on a 1973 1-ton. I found it easiest to just sawzall everything at the fittings. I could then get the fittings off the lines using a 6 point socket, put them on a wire wheel and re-use them, as well as it was FAST. I went to autozone, bought a roll of brake line, borrowed their flare tool and one afternoon later-voila!
[QUOTE=yugz;3224954] I found it easiest to just sawzall everything at the fittings. I could then get the fittings off the lines using a 6 point socket, put them on a wire wheel and re-use them, as well as it was FAST.
Been there too. It fast and less headache.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
This is not fun. Well ti took some time today but i got the passenger side all done and buttoned up, got the drivers side tore down and almost put back together. I gotta flare the line going to the caliper and I should be good to go for the front....... Good times!
