Old 03-28-2009, 07:07 PM   #1
Rust Buster
Rust Buster's Avatar
Pulling my hair out fitting panels!
I am really bummed. I've spent the last several months working the original sheetmetal on my build (link below) to get all the panels lined up. I finally gave up and bought all new tri-plus doors, fenders, and hood.
So I spent one weekend on the doors, figured out that the PO had replaced the rockers way back when and had installed them too high, which threw everything off. Fixed that, and decided to go back and use the original doors because they are just much much beefier and well made. Had to cut the hoops and re-weld them to match the top door opening.
Now the fenders and hood... It is hard to tell from my pics, and they look worse in person, but the Tri-plus hoods and fenders do not match in contour (top of fender and sides of hood). The front slope of the hood is not as steep as the fenders. How can this be, and what to do? I'm thinking it is better to cut the fenders and reslope them since they don't get banged around like the hood. Any thoughts are very much appreciated. I've been through a few original 67-68 hoods and they all needed more work than they are worth and all had the dent/sag in the center.
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 03-28-2009, 07:15 PM   #2
msgross
msgross's Avatar
Re: Pulling my hair out fitting panels!
It's only metal... "whatever it takes" I guess..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-28-2009, 07:16 PM   #3
Rust Buster
Thanks Mike, I'm doing the best I can now, self medicating with beer. I am soooo sick of fitting panels that just won't fit!
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-28-2009, 07:57 PM   #4
fine69
fine69's Avatar
They didnt fit worth a crap from the factory.
I have a 68 Chevy that has NEVER been apart. Fit sucks.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 03-28-2009, 08:01 PM   #5
Rust Buster
Yeah, I think I need to quit trying to get things so perfect and just accept that I can't polish a turd
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-28-2009, 08:10 PM   #6
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Talking Re: Pulling my hair out fitting panels!
it can be done , I had worked on 67 68 69 camaro's and chevelle's for several year's prior to finding my 67 C10 and boy did it hit me like a sledge hammer how BAD THE GAP's AND PANEL FIT ON THES TRUCK's WAS !
,,,,,,,,,,,,,,just remember all that matter's is the final fit , what you did to make it fit DON't MATTER !
REPRO TAILGATE !
REPRO GATE #2
panel fit (DOOR)
panel fit (DOOR) 2
hood fit
door
hood
panel fit door (PRIMER)
you can do it !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-28-2009, 08:23 PM   #7
19673ontree
CAN'T FIX NOTHIN
here is a good example of what you have to do sometime's , look close at the front fender patch IT WAS A 1" TO SHORT ! you can see where I had to cut it in half and widen it to get it to fit correctly !
underdash AC
Old 03-28-2009, 08:28 PM   #8
68gmsee
Active Member
68gmsee's Avatar
We feel the pain. My completely stock 68 GMC's sheetmetal fit leaves something to be desired also. But, I have to say that GM was not concerned about these trucks being perfect in those days. They were primarily for work so perfect alignment was not their priority. As these trucks became more of a family vehicle they started putting more emphasis in these areas.
In the meantime, I try to consider it a challenge and not get too frustrated.
I need another beer.
68gmsee is offline   Reply With Quote
Old 03-28-2009, 08:32 PM   #9
Rust Buster
Thanks for the encouragement everyone, that's why I love this site! I am hoping (but I am betting the opposite is true), that the original fenders will match the aftermarket hood, so I can just swap the fenders out. I just don't want to have to hunt again for a 67-68 hood that does not have a sag in the middle like all the others...
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 03-28-2009, 08:43 PM   #10
msgross
msgross's Avatar
wasn't GM tolerance like 1/4"? I think I heard that from GMC Paul or somebody...
The Garage:
Old 03-28-2009, 09:10 PM   #11
19673ontree
CAN'T FIX NOTHIN
Wink Re: Pulling my hair out fitting panels!
if it was the ruler they used was WAY OFF !
underdash AC
Old 03-28-2009, 09:20 PM   #12
msgross
msgross's Avatar
1/4" for every gap is a lot though... maybe it was 1/4" for each panel, that's 1/2" for each gap!
The Garage:
Old 03-28-2009, 09:23 PM   #13
Green Machine
Green Machine's Avatar
For whatever it is worth, we bought a pair of tri plus fenders for our 68 when it got redone. The front slope of the fenders did not match the hood, the headlight opening was to large, but a turnbuckle between the upper and lower grill holes pulled that into shape. Had problems with the rear mounts on top where it bolts to the cowl, had to use a bunch of shims and then those mounts points hit the hood when shut.
Finally had enough and repaired the originals, the new tri plus are still sitting here colleting dust. Going to cut one up for patch panels for our next project, no more of those for us.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-28-2009, 10:57 PM   #14
westofb
I really hate wet sanding!
westofb's Avatar
Sometimes take some improvising to make things fit better. Have used many things in past like a ratchet straps to pull radiator supports over, and of course the block of wood and a big f***ing hammer. Like mentioned by others it is end result that counts not the methods it takes getting there....good luck with those panels!
westofb is offline   Reply With Quote
Old 03-29-2009, 12:10 AM   #15
PHAT TONY
PHAT TONY's Avatar
Split the differences; smoke and mirrors. If you're gonna start cutting and welding make sure to remove and re-fit the panel before you call it "done" to make sure some heat didn't change anything.
PHAT TONY is offline   Reply With Quote
Old 03-29-2009, 10:08 AM   #16
mbgmike
AIn't body work Fun Its probably not your case but one thing it seems most people do is assume that the frame and/or body is even straight when they start. It looks OK I hear alot. If you are trying to do a real pro job, get the frame checked out. We have had guys come over and they show us their problems with the panels fitting poorly and after putting them on a frame machine alot of the times those problems can go away. It is probably the most overlooked thing that people will do to save money. Granted it will not solve all problems with panel alignment.
mbgmike is offline   Reply With Quote
Old 03-29-2009, 10:47 AM   #17
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Rust Buster View Post
......... I just don't want to have to hunt again for a 67-68 hood that does not have a sag in the middle like all the others...
Bowed hoods are a common problem on these trucks. You may be able to straighten them out if they're not severely damged with a little tlc. New pads can help as well as slight persuasion with the proper technique.
I've had luck using some of the ideas some of the guys here have used to straighten them out.
Here's some past posts re: bowed hoods.
http://67-72chevytrucks.com/vboard/s...ight=bent+hood
http://67-72chevytrucks.com/vboard/s...od#post1785818
