Old 03-28-2009, 09:24 PM   #1
joehalford01
joehalford01's Avatar
fixed the muffler, now onto other noises
Hey guys,
I finally had a day where i could pull the truck out of the garage and accomplish a little something. I replaced the wire coat hanger with a real muffler hanger so the muffler wouldn't rest on the driveshaft anymore . Took it for a real test drive this time lol. I didn't go far though, just around the block so I could a feel for things. (i'll take it on a real drive once i get some tires for it that arn't scary looking).
Anyways, the tranny does make hella noise. Some of it was the muffler on the driveshaft but otherwise yeah, it's still pretty noisy. It makes a light scraping noise in neutral while the engine is running until you push the clutch in. Once you go into gear it continues to make that noise. Thats the best way to describe it. It actually has really good power and nothing slips out of gear, it goes through all four gears, just makes this constant scraping noise. there could be more to it but thats all i have for now. still need to change the oil in it before i do anything else. Any thoughts?
joehalford01 is offline   Reply With Quote
Old 03-28-2009, 10:04 PM   #2
LILRED66
LILRED66's Avatar
Re: fixed the muffler, now onto other noises
I would check the throw-out bearing in the transmission, as well as, the carrier bearing on the drive shaft, if you have one.
LILRED66 is offline   Reply With Quote
Old 03-28-2009, 10:12 PM   #3
19GMC63
19GMC63's Avatar
sounds more like the pilot bushing.
Usually, T/O bearings make noise when the clutch is being depressed, but I could be wrong.
19GMC63 is offline   Reply With Quote
Old 03-28-2009, 10:16 PM   #4
joe231
joe231's Avatar
throw out bearings are noisy when the clutch is released, quiet with the pedal depressed
CHEVY ONLY
Old 03-28-2009, 10:19 PM   #5
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
as per your last post on this topic-
Have you checked the fluid in your tranny yet?
Checked differential fluid ?
Checked driveshaft to make sure it's not hitting anything else?
another far-out thought/ Are your tires/rims hitting anywhere?
Keep us posted***
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 03-29-2009, 11:31 AM   #6
joehalford01
thank you guys, i will check all these. i've never worked on a four speed so i wasn't even sure where to start.
