Old 12-20-2002, 06:49 PM   #1
pat
pat's Avatar
6 lug to 5 lug swap worth it?
I plan on getting drop spindles, so the front swap will be no problem (5 lug spindles actually $10 less than 6 lug). How much work to swap the rear axle, what options, cost, etc. Also, what quantity of good 6 lug rims are there? Thanks
pat is offline   Reply With Quote
Old 12-20-2002, 08:42 PM   #2
Hutch
Hutch's Avatar
I think it is a good swap.
You might get away with just an axle swap for the rear. (Depending on your year model)
One reason to keep it six lugs is: if you already have a substantial investment in your current wheels.
There is a good supply of the Chevrolet Rally wheels available in both six and five lug in the 15x8 size. Check at the local swap meets.
If you like the larger diameter wheels then 5 lugs is the way to go.
Some members have just had their six-lug rear axles plugged and redrilled for the 5 on 5-lug pattern.
Front rotors are less expensive in the more generic 5-lug variety.
Don't forget the spare you never know when you will need it.
Overall it makes good sense to go with the 5-lug swap.
Here are some helpful board hints:
When asking advice on a post it is a good idea to have the model of you truck in the post or in your signature, so others can give the best advice without guessing.
Another good idea is to give a specific city in your profile. People are more willing to give more local specific information regarding Shops and people that are close to you that might be of help.
When selling parts or vehicles on the parts board you know that everyone will want to see pics so be prepared
Welcome to the best Chevy Truck Board on the web
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 12-21-2002, 12:11 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I did a swap on my '69, and kept the 6-lug pattern. Why? Well, I didn't want to change the wheels, nor did I want to change the rear end. In the future, IF I find a 71-72 rear axle, AND I want to, I can put it in and swap the rotors on the front and have a 5-lug system. Your truck will never know which one it has. There are a butt-load of 6-lug wheels on the market.
One thing to remember, is that switching to a disc-brake front end will add about an inch of track to your vehicle. With that in mind, you will have to watch the width and offset of the wheels that you run on the front. Early Classic Enterprises components have been thoroughly reliable and make my truck a dream to drive.
Now, if I can just get my automatic choke sorted out, the cold weather won't plague me!
Member Nr. 2770
Old 12-21-2002, 06:14 PM   #4
pat
pat's Avatar
Thanks for the info Hutch and ChevLoRay. Im still thinking about the switch, I think I can get a 5 lug rear end from my friends wrecked '69. Im updating my profile now too, thanks for tips.
Old 12-22-2002, 12:51 AM   #5
1968GMC
love my truck
1968GMC's Avatar
69 has 6 lug unless your frend already changed it in the past.
1968GMC is offline   Reply With Quote
Old 12-22-2002, 01:35 PM   #6
Reumster
L.E.D. Freak
Reumster's Avatar
It's worth it to do the swap. You can many times just find a 71 72 at the junk yard and buy what you need. It's worth it in the long run, as far as wheels, safty of disk brakes. And looks.
Do it. If you plan on keeping the truck.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 12-22-2002, 07:02 PM   #7
pat
pat's Avatar
What all would i need to take off of the donor truck?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
Old 12-22-2002, 07:10 PM   #8
Iron-Butt
454 club
Iron-Butt's Avatar
5 lug more options
there are more options for the 5 lug. I like mine better with the 5 lug conversion.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 12-22-2002, 09:35 PM   #9
crazy longhorn
Fabricate till you "puke"
Pat, for parts off the donor truck, you will need..... spindles, rotors , calipers, lower a arms, centerlink & tierod assys, master , lines,hoses & prop block. Also you need to install new balljoint assys(go for the yr of the spindle).On the balljoints 71-72 are the same, 73 up the upper ball joint & outer tierod have a different taper. At the rear on your 68, the best /cheapest way would be to swap a 71-72 diff in (complete)....67-69 housings are 1 1/2" narrower that the 70-72(70 is 6 lug, but the 71-72 axles shafts will fit. Good luck.....AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
