71 BB Turbo 400 wiring bolt location
I purchased a new TCS harness because it is part of the kickdown wiring that goes to the turbo 400. The part of the harness that goes to the transmission has a bracket on it that is used to hold the harness somewhere behind the engine with a bolt. The bracket does not line up with any bolts. My original harness was so bad that it wasn't mounted to anything. In fact it was falling apart. I assume it should mount either to a bolt hole on the rear of the head or to the bell housing, but it doesn't line up so it's got me stumped. Can someone with an original setup take a look and see where this harness bracket is supposed to be bolted down?
Re: 71 BB Turbo 400 wiring bolt location
The origninal harness bracket for the TH 400 attached to the bell housing bolt, (second from top on the left as I recall).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
