Old 03-29-2009, 10:40 AM   #1
bigarmzz
bigarmzz's Avatar
is it ok to run 3" springs?
i've been reading through some old threads, and it seems like most dont recommend using the 3" springs with lowering the truck
i already ordered 2.5" WC spindles, and was wanting to use 3" springs in the front for a total of 5.5" front, and rear a 5" DJM flip kit, with a 2" drop shackle for a total of 5.5/7
should i go with 2.5" springs instead? or will my front end "geometry" be ok? thanks
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 03-29-2009, 11:23 AM   #2
boatpuller
boatpuller's Avatar
Re: is it ok to run 3" springs?
like most things people have done it.and other's don't reccomend it.i remember reading where it gave some guy's problem's. a 3 inch drop spindle with a 2 inch coil is a better way to get 5, in my opinion.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-29-2009, 12:00 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
I never recommend a 3" spring. It's just too much drop to achieve correctly from a spring. It will be prone to a harsh ride and bottoming out. Yes there are those that have them and are happy. I just don't think they are aware of what a 1-2" spring feels like.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-29-2009, 12:13 PM   #4
Slammed '87
Slammed '87's Avatar
I bought a set of DJM 3" drop springs years ago. They were just right for a few months but after that they sagged and ended up dropping the front about 4". This was fine with me tho. I removed the bumpstops (as you would with air bags) and had it realigned. I didn't have drop spindles so there was no clearance concern. Alot of people have problems with lowering coils but the way i see it it's no different than have air bags (just no adjustability). If you want low i'd say go for the 3". Just make sure it's realigned right after or your tires will be trash.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
Old 03-29-2009, 12:30 PM   #5
bigarmzz
bigarmzz's Avatar
i guess looking back at it, i should have got 3" spindles and 2 or 2.5" springs...you know what they say about that
you guys know if western chassis springs sag much over time? maybe if i just go 2.5" spindles with there 2.5" springs, i should be fine
my 20" coys should be here this week, so i'm just trying to get my "ducks in a row"
Old 03-29-2009, 01:41 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
I have 3" spindles and springs, its ride's ok for a truck, but the lower control arms scrape on about every dip in the road and pothole, but its really bother me that bad
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-29-2009, 02:40 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, you should have gone with 3" spindles. Unless you want to reorder and sell those its a bit late. If I were you I would cut one coil off the stock spring and see where it sets. If that's not enough get the 2.5 or 3" spring.
Articles-
"Refining Sierra"
Old 03-29-2009, 04:27 PM   #8
JohnC
JohnC's Avatar
This answers a few questions for me as well. Looking at doing something similar down the road. Let us know when you get it all installed. What Coy wheels are you going with?
JohnC is offline   Reply With Quote
Old 03-29-2009, 06:10 PM   #9
1984 swb chevy
1984 swb chevy's Avatar
if you are running 20's up front your lower control arms wont scrape as much as someone with 15's or 17's. You will have more ground clearance. My lowere were very close to the ground with the 15's up front.
2010 Tahoe
1984 C10
2005 Harley FLH
1941 Willys Pickup (will never get it done) not for sale
1984 swb chevy is offline   Reply With Quote
Old 03-29-2009, 10:52 PM   #10
slugish
Slugish
Have had 2.5 spindles & 3 in Eibach springs on my 84 for about 3 yr,s now . dosent ride great but it works . Unless you go into money airbagging , its a trade off between ride comfort & looks . Dont buy the cheapest coils if you get 2.5 or 3,s
slugish is offline   Reply With Quote
Old 03-30-2009, 12:18 AM   #11
Square84
I don't think these pills work
Square84's Avatar
iv'e been running western chassis 3 inch springs for 4 years now and they ride great but i did put belltech drop shocks on it and cut the bumpstop and perch off. i recently put new balljoints in to replace the originals and had it realigned and the guy said it was fine just off a hair, so i dont know if it was the 4 year old spings or replacing the 25 year old ball joints? either way i'm satisfied with the spring but i didn't like westerns' tech line guys or there managers.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
