It actually runs!!!!
Well, I was able to make some good progress this weekend. It starts and runs like a champ! It is missing a bit under load, so I hope to go out and check the ignition system today.
The way it should be ![]() |
Old member
Re: It actually runs!!!!
Nothing like getting something to work on your own. Feels good don't it!
Nice trucks you have there, That GMC looks right at home in the garage. ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Active Member
![]() Join Date: Jul 2007
Great going! Another old truck brought back to life... I bet the neighbors ain't too pleased, though.
![]() I had one call the city on me cause I had my old 69 parked in the driveway unlicensed. Had to move it out to my country property. |
My neighbors are actually pretty cool. One of them said "let's go around the block". Of course what do you do? We went around the block...a few times
laying low
![]() Join Date: Mar 2001
Good neighbors you have there.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
I do have a question about the miss. It still has points, and I'm only familiar with the points systems in VWs. Do they slowly go out, or is it an all or nothing thing?
laying low
Yes the points do wear down some. The point gap will close up with wear. I don't know what your plans are for the truck but probably a full tuneup is in order if you intend to run it much. I would pull and inspect all the plugs, check the vacumn advance, check the points dwell, timing, fuel filter and such. If you don't have a dwell meter you can get it real close with a feeler gauge. Around 28-32 on the dwell angle.
Consider trading out the dizzy for an HEI unit - huge upgrade at a small price. I got a new one on Ebay for around $75.00.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
I actually have one from my brother-in-law's 400 SB. I just bought a new cap, rotor, and coil for it. So I may just swap it out.
#10 | |
It is not rocket science, and someone with limited knowledge of car electronics can do it, (like me). Oh yeah, did your give you the spark plug wires?
'72 GMC custom camper 350/350 |
No, I was going to replace the plugs and wires as well when I do this. I've been searching for tips on this swap. Is there an FAQ on this?
#12 | |
I learned about this problem the hard way, by frying an MSD module and had to have the truck, flat bedded home. That was about a $120 lesson ![]()
'72 GMC custom camper 350/350 Last edited by spinning wheels; 03-29-2009 at 04:35 PM. |
#13 |
Well, I'll search around and see what I can find before I make the swap. I imagine from what I've read so far, the points definitely need to be adjusted on this truck. That might be all I do today
#14 | |
Good luck.
#15 | |
#16 |
Well, changed the oil and bought the parts for the HEI
I think I'll tackle this next weekend after researching the h3ll out of it ![]() |
#17 |
I'm a poor spectator
It's easy to do. Run a pretty thick (10 or 12 guage) wire with a spade connector under the dash to the fuse box (the box has accomadations for the spade connector. Then hook the other end to your dizzy. Viola!!!!!
OR... If you must be different you can run it to a relay mounted on the fender that will completely isolate it from everything else which isn't really necessary but you can do it. It's up to you, the first way I said is WAAAAAAAAAYYYYY easier and quicker.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#18 | |
![]() Join Date: Jan 2009
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
