Quick Question About Pedal Assembly
I am putting a t56 in my blazer and I need a clutch pedal. Does my auto bracket have the hole for the clutch or will I have to get the bracket from a manual truck?
Thanks, |
resident oilfield trash
Re: Quick Question About Pedal Assembly
If you end up needing the Manual bracket I have one
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
muddobber
your pedal assembly will work you just have to remove the bolt tha holds the brake pedal and put you clutch pedal. dont forget you need a return spring
I thought thet are the same bracket but I wasn't sure. Thanks for the info.
