Old 03-29-2009, 12:21 PM   #1
mothertrucker424
mothertrucker424's Avatar
tire size
i am currently swaping in my 1/2 ton axles for some stronger 3/4 ton axles eaton in rear and a dana 44 in front
i need to know what size tire to run i have 4.10 gearing i drive alot of roads some wheeling and i pull a trailer ocasionally i am running a 16.5x 10 rim
stock 350/350 power plant
i have 4" of lift but i can make taller
i also would like to run the tallest possible tire
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 03-29-2009, 01:25 PM   #2
b454rat
Re: tire size
I ran 35s with 4.10s, had decent pulling power and was OK on the highway. I'd say 35s, maybe 33s to give you little more oomph.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-29-2009, 01:27 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: tire size
My K20 has 4.10s in the same axles, and 33x12.50s on 16.5x9.75" wheels (just slightly taller than the stock 7.50-16s). You'd have no problems with that size, but with 4" of lift and wanting a tall tire.... I'd go with 35x12.50-16.5s.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-29-2009, 07:13 PM   #4
mothertrucker424
Re: tire size
i,ve been looking at a 35-37" tire range what width is correct
Old 03-29-2009, 07:34 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: tire size
how about 12.50??
- Mike -
RIP El Jay
Old 04-02-2009, 06:23 AM   #6
mothertrucker424
Re: tire size
thank you
