Old 03-29-2009, 12:35 PM   #1
frankyjoet
Smile dist ?
HI, have 350 sb w/hei dist. At end of dist shaft there is supposed to be a rod
that goes into the oil pump shaft. If it falls out, is it easy to replace. Found this out from an engine builder. Would also like to see a video of a dist gear
being placed in the engine. many thanks
joeyt
Please email at frankyjoet@gmail.com
Last edited by frankyjoet; 03-29-2009 at 12:42 PM. Reason: to include email address
frankyjoet is offline   Reply With Quote
Old 03-29-2009, 01:13 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: dist ?
I'm going to get this moved to the correct part of the board.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-29-2009, 02:58 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: dist ?
Not sure what you mean by a movie of a distributor gear being installed in the engine. Basically the dis is dropped into the distributor hole but making sure the slot is aligned so that it matches the oil pump slot.
The distributor will rotate slightly as you insert it so there's a lot of pulling it out, tweaking the oil pump slot with a long shaft screwdriver or rotating the dis backwards a little bit and trying again. I've had to do it as much as 3 or 4 times to get it just right.
One other thing you have to do, is make sure your #1 piston is at TDC and lined up with the timing mark on the engine.
Here's a good pictorial of dis rebuilding.
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
68gmsee is offline   Reply With Quote
Old 03-29-2009, 03:53 PM   #4
jholley
jholley's Avatar
Re: dist ?
The rod you are talking about goes in from the bottom. The oil pump holds it in. The bottom most part of the distributor is the drive gear that meshes with the cam. If you look down the distributor hole you will see the top of that rod, it has a slot. Inside the bottom of the distributor drive gear you'll see the tab that goes in the slot of the oil pump drive rod.
Long story short, nothing should fall off when you pull the distributor out.
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
