BB Motor mounts & Frame mounts
I found a set of frame mounts on sale from Brothers for a BB in a 68 and was wondering if any one has them installed on their truck. Do they mount the engine in the same location as the original factory mounts do? I already have a new set of frame and engine mounts installed now that I got a couple of years back, but I am concerned if one of the engine mounts break, will I be able to find replacements. They weren't easy to find. I have the trans mount located and installed, the drive shaft has been cut to lenght and installed, so the location of the engine needs to remain the same.
1968 Chevy shortbed fleetside Pro Street |
Moderator
![]() Join Date: May 2007
Re: BB Motor mounts & Frame mounts
I have a set of factory 72 bbc engine mounts for sale if you are interested. They bolt right up and are a stronger design than the saddle-type mounts used from 68-71.
The ones from brothers are aftermarket, and I am not sure if they will bolt into the factory frame holes. Based on my prior experiences with aftermarket mounts, I would say that they do not. I am sure someone else will chime in to verify this. |
Do you have any pics of them?
Moderator
Here is a link: http://67-72chevytrucks.com/vboard/s...d.php?t=326543
Those will bolt up to a 68 without any Mods any retain the same location?
Moderator
If you are using the factory saddle-type mounts now, yes these will keep it in the same location.
I have the original style mounts now. Can you PM me so I can send you some pics?
Moderator
It says that you are unable to receive PM's?? My email addy is leddzepp@yahoo.com if you want to send pics.
