Old 03-29-2009, 01:15 PM   #1
tim21391
tim21391's Avatar
POR-15, Undercoar, or Trim Black
which should i use for a radiator support that has been sand blasted and a bit pitted in spots?? im thinking undercoating since i can get a textured look form that and it would fill in the pit holes....
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-29-2009, 01:33 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: POR-15, Undercoar, or Trim Black
Por-15
It is self-leveling, and you can also fill in the pit holes with it. It will permanently bond to the metal, and will never rust again.
leddzepp is offline   Reply With Quote
Old 03-29-2009, 02:55 PM   #3
tim21391
tim21391's Avatar
where is that located? autozone right? and u got an estimate on price?
Old 03-29-2009, 03:02 PM   #4
chev-obsession
chev-obsession's Avatar
i dont know about autozone. but Baxter auto parts sells it. i dont know if you have a baxters where you live but here they usually keep it in stock. if not then try your local auto body supply store, they should have it or something generic.
chev-obsession is offline   Reply With Quote
Old 03-29-2009, 03:32 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Autozone does not sell Por 15. There are a handful of vendors that carry it. One of them sells it on ebay, and I have bought from him with no problems. You can also order from them direct.
It is very cost effective. One of the small cans runs about 10 bucks or less. That alone is more than enought to do an entire chassis if it is thinned 20% and air brushed on. I think the pint cans run around $22 or so....been a while since I have had to buy some. Beware that once it is exposed to air, it cures pretty fast!
Old 03-29-2009, 04:04 PM   #6
69halfton
69halfton's Avatar
dont know what your budget is on the build...have you considered a spray-on bedliner type matirial?
we have a place here in canada called Line X they do the spray in bed liners, but they can spray it on whatever you like. that stuff it seriously tough, and it will seal right up and you'l have no rust issues every again.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-29-2009, 06:54 PM   #7
Dynomutt
Dynomutt's Avatar
Try your local auto paint supplier. A lot of them sell POR 15 or similar. If you can't find one, ask a local paint and body shop where they buy their paint/supplies. It will be somewhere local I'm sure.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 03-29-2009, 07:06 PM   #8
tim21391
tim21391's Avatar
they do line x at my work.. wasnt thinking to spend that kinda money.. ill check out the body shop supplier place tomorrow
Old 03-29-2009, 07:17 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
POR hands down...esp if its a driver
