03-29-2009, 02:25 PM | #1 |
Sway bar Questions
Ive been reading alot about sway bars and have a few ideas for the rear but i never ran across any post on what was being used for the front sway bar. Is this just something i have to find off of another 67-72 or can i get one off something else? I would like to add at least the front to my soon to be shop truck But plan on running both on my SWB. Oh and while im thinking of it are you guys with the rear making your brackets for the frame mount part or does someone make a kit or something for them.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
03-29-2009, 02:36 PM | #2 |
I am a Referee of life.
Re: Sway bar Questions
Later model truck ones also work.I can't remember what all fits but there should be a write up in the FAQ's.It will give you more info than I can.The rears are also available.IIRC there is a write up on a Camaro one in the FAQ's also.You might also do a search since someone has probably done one in their build thread.There are also aftermarket ones but IIRC they run in the $150.00+ range and most can get one from a wrecking yard for about $40.00-50.00
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 03-29-2009 at 02:37 PM. |
03-29-2009, 02:42 PM | #3 |
I did a search and read lots of installs but none that i seen mentioned what bar they were using. But Im headed to the FAQ section now. Thanks and i realy like the camaro one on the rear and im pretty sure thats the way im going for my SWB.
03-29-2009, 04:47 PM | #4 |
Being that I do not have the luxury of junkyards down here with older vehicles I ordered both of mine from CPP and installed them very happy with my purchase.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
03-29-2009, 08:46 PM | #5 |
Watch out for your cornhole !
I did the FAQ article about swaybars. Be sure and check it out.
Any truck up to 87 will work, and any Suburban or heavy truck up through 91 will work on the older trucks.
03-30-2009, 02:47 PM | #6 |
I sifted thru the FAQ section and finally found it. It dosent show up on a search for some reason.
03-30-2009, 02:55 PM | #7 |
I got one off a 78 3/4 ton truck. It's beefy.
03-30-2009, 03:05 PM | #8 | |
Middle-aged Curmudgeon
The stock bar is 1 & 1/16" The bigger bar is 1 & 1/4" 3/16 of an inch doesn't sound like much difference but it looks about twice as beefy. Got mine at my local Pick-n-Pull for 12 bucks.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
