Old 03-29-2009, 02:54 PM   #1
bobs86silv
bobs86silv's Avatar
1981 12 bolt direct swap into 86 swb 10 bolt?
Ok I finally found a rearend with 3.73 gears. They are from a 1981 1/2 ton two wheel drive long bed. I would like to swap the rearend under my 86 swb 1/2 ton. I have dont alot of reading, and I can swap my backing plate and breaks and it should bolt right in right? Am I really going to have a drive shaft that is an inch too short? Is there an easy fix for this? There are quite a few 88,89,90 rearends I can get but I dont think they will work will they?
Robert
86 Silverado SWB 350/350/3.08 9.7-1 Forged pistons Eagle Rods Eagle Crank Zero Deck Balanced Blueprinted 180cc DART Heads Roller Rockers RPM Intake Demon Carb Flowtech Headers 400HP/400TQ
bobs86silv is offline   Reply With Quote
Old 03-29-2009, 03:36 PM   #2
rockn30809
Re: 1981 12 bolt direct swap into 86 swb 10 bolt?
I didn't swap backing plates and my drive shaft length was fine. All I had to do was get a conversion u-joint. My truck is a 87.
rockn30809 is offline   Reply With Quote
Old 03-29-2009, 06:09 PM   #3
80stepsideguy
Laid back freak
80stepsideguy's Avatar
Everything is a direct bolt in to your truck.81 was the last year of the 12 bolts as 82 and on were all 10 bolts in 1/2 ton trucks.Your original plates and u bolts should be a perfect fit as well as the e brake cables.I got a 3.73 rearend in my truck project as well but opted for the 700r4 due to the higher rpms the rearend will bring..
thanks
pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
Old 03-29-2009, 08:46 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Yes, I swapped a 77 12 bolt into my 83. You will have to change the rear u-joint. The 12 bolt u-joints have smaller caps.....or the 10 bolt does. I can't remember which one. Either way two will be large and two will be small.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-29-2009, 10:38 PM   #5
silvereagle07
silvereagle07's Avatar
Does anyone know the part number on the conversion u joint? I install a 12 bolt on my 84' but I forgot what the number was.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 03-30-2009, 07:35 PM   #6
rockn30809
precision is #372, spicer is 5-3022x
