Need advice
I need to get new hood hinges and wanted to know peoples thoughts with experience between after market and original GM fitting quality any thoughts?
cost is $80 for the pair after market and $170 for GM.
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 Last edited by teamradrz1; 03-29-2009 at 03:41 PM. |
Between Trucks...
Re: Need advise
I ordered some aftermarket ones with new springs, they work perfectly.
They were made in Argentina if I remember correctly.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 03-29-2009 at 05:46 PM. |
What?
Re: Need advise
bought some repro's myself, and they are just fine.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: Need advise
First I bought used ones from Manes, that was a bad idea. I then purchased the aftermarket new ones (also from Manes) and they worked out very well.
Active Member
![]() Join Date: Jul 2007
Re: Need advise
Some guys have posted on here to make sure and lubricate them real well before installing them to prevent buckling.
I'd probably lube them and then slowly lower and raise the hood a little at time until they move freely. |
Moderator
![]() Join Date: May 2007
Re: Need advise
I lubed the crap out of mine. Be careful after you do it though....my hood flys open when I pop the latch now
Re: Need advise
cool thanks everyone! Saving money sounds good to me!
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
The Red Menace
Re: Need advise
How much do the springs have to do with that? My hood doesn't pop up and has to be helped open. The hinges seem fine so I'm assuming it's the springs.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
Moderator
Re: Need advise
