What size
here is a pic of 33 in the front
![]() Here is a pic of 35 in the front ![]() Which size do you think i should run im going to buy a set of boggers soon, and would like to know what you guys think. I'm not only going to do bogging i'm going to everything i can offroad, trails and rock crawling, so i don't want to go any higher than 6in lift which i have now.
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 03-29-2009 at 05:35 PM. |
Re: What size
35's all the way. Hopefully you have 4.10's or 4.56's!
john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
Re: What size
o, that reminds me that to say i have 4.10s, and i have to delete that last pic i knew something was wrong.
![]() 72 gmc 2500 2wd drive convert ![]() My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
Re: What size
I meant to comment on that one! Nice eel!
Re: What size
im going to buy it pretty soon, if i go to rubicon because the pet store is on the way home from there.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: What size
With that much lift.... 35s.
Re: What size
i like the 35s or even a set of 37s
Re: What size
i will clear 37s but if i try tank trap it will rub a lot.
![]() Join Date: Nov 2006
Re: What size
I also think 37's would be perfect but if you are going to be doing some wheelin and don't want to trim the fenders than the 35's for sure!
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris |
Re: What size
I will have to be diffrent and go against the group and say 35's. yes 35's for shure!
i've created a monster
Re: What size
if your suspension allows for much off-camber, i'm quite positive you will have to go no larger than 35's, and i personally wouldn't go smaller than that if you're looking to do any rock climbing. so, all in all, 35 is the place to start, and make sure every run is a learning curve
