Got earplugs?
Can you tell if you have a dana 60 rearend just by looking at the gear cover?
1968 GMC Original A/C, bucket seats, PS,PB 396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression Alltogether 411HP and 446ft/lbs Dana 60 w/ 3.54 gears Turbo 400 tranny Why would you have anything other than a big block? HAHA |
Suburbans RULE!
Yes......this is a Dana 60.....
![]() ------------------ 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
