Pat
2.02 heads on my 307?
can it be done?
Re: 2.02 heads on my 307?
I dont see why not!!!! I ran some 2.02 1.60s on a 327 350 385 stroker!!!
1968 GMC Rebuilding Stage ![]() 2001 Camaro SS SOLD ![]() |
Pat
so i wont have a problem with valve clearance?
![]() Join Date: Mar 2006
what size chambers do you have on the 2.02 heads? 2.02 valves in 76 cc heads are great but with 64 chamber heads tend to bring your compression up.
What kind of pistons are you running? I always ran flat tops!!!
You might have valve size problems with those heads on that block, that is the valves are actually too big to fit the smaller cylinder bore of the 307, I could be completely wrong though, someone else will chime in on this for sure.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
Pat
probably 70cc chambers, and running flat top pistons.
i was wondering about the valves not clear the cylinder, thats why i posted lol |
I tried doing some research and i coiuldnt find anything about putting those heads on a 307!!!! Will do some more searching!!! Sorry i thouhgt you was worried about piston clearance!!!
Super Chevy did a build on a 307 Here is the right up!!!!
http://www.superchevy.com/technical/...nce/index.html
if in doubt take the bare block put the heads on and look up the bore with a flashlight
Pat
sounds good cdowns
im actually trying to figure out what i want on it i posted a while back about what to do with my 307 and everyone said vortec but im thinking either 1.92 or 2.02 edelbrocks |
If I am correct the 2.02 valves will clear but they will be so close to the cylinder wall that the intake valve will be shrouded and a 1.94 valve will flow better.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin ![]() 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
#13 |
![]() The heads used in the Super Chevy article above are Edelbrocks E-Tec heads which are basicaly just an aluminum verson of the Vortecs. They still have the same 1.94/1.55 valves like the GM peices. The aluminum heads might give you a slighter increase in power over the cast iron heads, but not enough for the money spent. I would say with a mild 262 cam like used above, a set of GM Vortecs, and Edelbrock intake and a good carb, you would still very well be in the 300 hp mark if not just a little higher.
#14 |
Pat
will i need a roller cam for the vortecs?
#15 |
![]() Join Date: Dec 2008
Everyone told me Vortecs? so why would you put 2.02's on it, bigger is not always better, right ?
#16 |
Pat
edelbrock make vortec?
#17 |
Do not use 2.02's on a small bore block there is a strong possibility of contact of the valve face with the bore.
'96 K2500 GMC 6.5 4L80E '88 c1500 RCSB lowered 4 & 6 454 TH700R4 (still being built) '79 K20 Chevy 400 4 spd '69 K20 Chevy 406 4spd '70 K10 Chevy 355 4spd 6 inch lift '70 C-20 (son's truck) originally 292 4spd now a 350 4spd Hey I didn't even want to until you told me I couldn't ! ![]() ![]() |
#18 |
Pat
what do you think og these?
http://cgi.ebay.ca/SBC-CHEVY-ALUMINU...1%7C240%3A1318 would i have to change my flat top pistons to run pump gas? |
#19 |
Pat
something like that except 1.94's
#20 | |
http://store.summitracing.com/partde...5&autoview=sku Runner volume is perfect, and with the 67 cc chamber should be good with pump premium.
#21 |
You can run 202's on a 307 with no issues. The bore is not as small as most people think. The real problem is your going to be running bigger valves for a setup that really dosent need it. Now if your were running around a 480 or so lift then i could see bigger valves but for your setup i would not spend the money. But thats just my .02 cents and its your money so the real decision is up to you.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
#22 |
I built a nice running 307 once and I ran 1.94s.I don`t think you`d see a benefit going with more valve.I`d stay with 1.94s.I think 2.02s will make a bad combination.
#23 |
![]() Join Date: Jan 2008
2.02's will be overkill. You would probably be better with the 1.94's. It's all about the combination! Bigger isn't always better, unless it's your bank account!My .02
