Old 03-30-2009, 12:26 AM   #1
short-t
short-t's Avatar
ECE front disk brake/drop kit = wider front end!
Had a buddy over the other night after installing the ECE disk brakes / drop spindles on my 68 C10. He was looking at it and said the front looks wider than the back. So I get out the tape measure and check the front and back width. The front is now about 3.5” wider than the back! So after doing a search I found this thread: http://67-72chevytrucks.com/vboard/s...ighlight=width
The only thing I can see doing now is changing the wheels and the offset to get them the same? I was really hoping to reuse the 6 lug wheels that I have, didn’t budget for a new set of wheels, tires, and axels. (5lug)
Does anyone have any suggestions for me??
short-t is offline   Reply With Quote
Old 03-30-2009, 12:45 AM   #2
CG
BlahBlahBlah
Re: ECE front disk brake/drop kit = wider front end!
Adding disks like you did widens the front around 3 inches. I believe stock the front is a little wider to begin with. CPP makes drop spindles that move the track in an inch and an eighth. Although its a pain, you may want to sell your ECE's and get CPP's. Not much else you can do. Im having the same difficulties with a truck Im putting together.
Old 03-30-2009, 12:52 AM   #3
short-t
short-t's Avatar
I sure wished ECE would have disclosed that their kit would widen the front end! Does the CPP spindles use the 1968 ball joints/tie rod ends?
Old 03-30-2009, 12:56 AM   #4
CG
BlahBlahBlah
You're going to have to give them a call and get the exact specs.
ECE is a super reputable company, so Im not sure why it doesnt say that somewhere in the specs of their products.
Its not just their (ECE) drop spindle disk kit...its everyones. Even CPP's normal one does that. CPP just recently came out with the one that brings it back in a little over an inch.
Old 03-30-2009, 01:02 AM   #5
short-t
short-t's Avatar
I was over at ECE site reading in the tech articles/drop spindles and found this sentence, Early Classic Drop Spindles are engineered to lower your truck 2½", allowing the maximum amount of front wheel backspacing on the market.
So does this mean that they push out the spindle so you can move the offset of the wheel out? I don't have the front clip back on the truck right now, how bad do you think it would look if I left it this way and used my 6 lug wheels?
Old 03-30-2009, 01:05 AM   #6
CG
BlahBlahBlah
Im not really the expert on this stuff. You may want to just put the truck together and see how it all looks before you make a decision.
Its late right now so not a lot of guys on the board. By tomorrow you will have a bunch of comments that will help you out Im sure.
Old 03-30-2009, 01:10 AM   #7
short-t
short-t's Avatar
Ya your right. It just seems like you do all of the research to avoid little problems like this and then murphy strikes!
Thanks for taking the time to help,
Greg
Old 03-30-2009, 02:18 AM   #8
jbristo67
resident oilfield trash
jbristo67's Avatar
McGauphys does and didnt widen my front end at all as far as i can tell but then again i am running a 72 rear
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-30-2009, 02:22 AM   #9
jbristo67
jbristo67's Avatar
Prob a little rough. I know GM widened the rears to match the widths of the front ends.
2011 Nissan Armada
Old 03-30-2009, 02:24 AM   #10
short-t
short-t's Avatar
The 72 rear is wider? I did not know that, maybe I could swap out the rear end with a later model one? How wide is the 72 rear?
Old 03-30-2009, 02:39 AM   #11
jbristo67
jbristo67's Avatar
Dont know for sure. Its like 1 3/4 or 2 wider than the 67-mid 70
2011 Nissan Armada
Old 03-30-2009, 06:07 AM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've put on ten or twelve sets of ECE spindles in my time.
They widen the front track 3/4 of an inch per side. That's it. I don't know where you arrived at the 3 inch dimension, but I think if you will assemble the truck and remeasure, you will indeed find 3/4 of an inch per side wider for a total of 1.5 inches.
This is common procedure. If you put a set of stock GM spindles for disc brakes on your truck, they would widen it by, you guessed it, 3/4 of an inch per side. All factory disc brake trucks were 1.5 inches wider track. I've installed BellTech, Western, ECE, Chassis Tech, and Ground Force spindles and they all do this.
In late 70, in preparation for the disc brake update in 1971, GM widened the rear axles 1.5 inches to compensate for the wider front track.
Personally, I usually run a 235 or 245 front tire and a 275 rear tire. The wide rear tire visually masks the difference and you can't tell.
Old 03-30-2009, 06:12 AM   #13
OARNGESI
OARNGESI's Avatar
You can ;ways ust adapters or spacers to move the rear wheels out
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-30-2009, 07:13 AM   #14
70c10
67-72 Addict!
70c10's Avatar
Tx Firefighter explained it right on! Run a narrower tire OR a 7" rim and you'll be fine.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-30-2009, 08:07 AM   #15
my67chevytruck
Under Construction
my67chevytruck's Avatar
^^^^ I agree.. Kevin explained it well!!!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-30-2009, 08:51 AM   #16
DrtyJack75
There's a considerable difference in the width (kind of hard to tell in a picture, tried to find pictures at same angle)....I was thinking the same thing but it's easily fixed with backspacing (if you plan to get new wheels) Here's a picture of my truck Pre-ECE Lowering and After...Im very happy with mine!
So much as my buddy saying that wasnt the original rearend for this truck and it had to of been changed my previous owner....lol....Hopefully this helps a bit...
DrtyJack75 is offline   Reply With Quote
Old 03-30-2009, 08:55 AM   #17
willyCJ
willyCJ's Avatar
I heard a few years back that a wider front axle vs. rear axle makes a vehicle stable. The solutions mentioned above are all sound imo.
1970 Shortbed C10
Parts I need:
Headlight Switch, Headlight retainers, Bezels (found, thanks jc)
wiper arms, wiper switch (found, thanks jc)
Carpet (blue/black preferred)
about half the e-brake cables (for a shortbed truck)
willyCJ is offline   Reply With Quote
Old 03-30-2009, 01:47 PM   #18
short-t
short-t's Avatar
I took the measurement from the inside lip of the rim to the other and repeated the same for the rear, I came up with 3.5. I guess to really measure it correctly I need to remove all of the wheels and take the measurement from the wheel mounting face of the rotors and drums?
The wheels that I was hoping to reuse are American Racing ATX Moab. They are 17X10 with 4.5” back spacing all around in 6 lug. The tire is a 255/60 R17, if I remember correctly the tire manufactures don’t seem to offer many different sizes in 17”.
So my options would be to,
1) find a Moab wheel that is narrower, say 7" to 8" wide
2) get a spacer for the rear wheels
3) convert to 5 lug and get some nice wheels with the proper back spacing
What should I do?
Thanks for the replies,
Greg
Old 03-30-2009, 02:05 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Personally what I think you should do is sell the truck to me and end your frustrations. Since your probably not going to do that, the most simple solution is to get a spacer for the rear wheels...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-30-2009, 02:24 PM   #20
short-t
short-t's Avatar
I just finished talking with Jeff over at ECE. He said that going from drums to disk widens the truck 1.5" total or 3/4" each side. He then told me that the drop spindles do take it out a bit more. (he couldn't remember the exact amount) Also Jeff did say that he would exchange the 6 lug rotors for the 5 lugs minus the shipping if I wanted to go that route.
If I were to try and find another AR Moab wheel for the front what would I need to get it inline?
Thanks,
Greg
Old 03-30-2009, 06:32 PM   #21
John Fabris
TOTY 2006
John Fabris's Avatar
Ditto on what TX Firefighter says. 67-70 all had drum, and updating to disc (whether aftermarket or OEM) will widen the front 1/5 to 2 inches. The guys at Early Classic even told me this way back when I was building my 67. In 71, disc were used, and due to being wider, they used wider rear ends as well.
Good Looking Truck by the way!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 05-10-2009, 02:03 PM   #22
short-t
short-t's Avatar
I managed to get the truck together to measure it up for some new Billet Specialties wheels. As it turns out the truck doesn't look half bad, I thought the front wheels would have been out past the fenders! For now I am going to put a set of wheel spacers on the back and run what I got.
Here are a few pictures of how it looks with the wheels and the new 3.5/5 ECE drop. Let me know what you think, I think it looks pretty good!
Old 05-10-2009, 03:58 PM   #23
CG
BlahBlahBlah
Your truck looks great. Glad it really wasnt three inch increase (I only know what I read on the board lol) Make sure you post lots of pics when its completely finished.
Old 05-10-2009, 05:02 PM   #24
Boog
laying low
Boog's Avatar
[For now I am going to put a set of wheel spacers on the back and run what I got]
That sounds like the best idea for now. Like you I thought the tires would stick out further on the front than they do but the position of the tire in the fender looks good.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-10-2009, 07:04 PM   #25
BossHogg69
motor exploder
BossHogg69's Avatar
Looks good to me, but if you just can't stand it, maybe a 3/8" or 1/2" spacer??? Don't know how much wheel stud you have to allow for the spacer.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
