Old 12-20-2002, 11:48 PM   #1
72MARIO
72MARIO's Avatar
3970010 Block Q's
I have that block (actually my dads) and he wants to use for a 383 build up. When he took it apart it only had 2 Bolt mains . Just wondering if it can be changed to a 4 main without weeking the block? or will it be okay as just a 2 bolt block. Its going to be mainly built for towing, approx 400 hp 450 ft.lbs. torque.the Dart SR stock replacement Iron head.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-21-2002, 12:07 AM   #2
crazy longhorn
Fabricate till you "puke"
You can upgrade to slayed aftermarket caps, but it gets a little pricey with caps & machine work. I would just install ARP main studs & run it.......my 383 is a 2 bolt block
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-21-2002, 12:10 AM   #3
bigjimzlll
bigjimzlll's Avatar
yup...arp main studs(get the ones for a windage tray) and align hone...I would only use 4 bolt splayed caps with a forged crank with a blower or gobs of nitrous
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 12-21-2002, 12:24 AM   #4
72MARIO
72MARIO's Avatar
what is a windage tray?>
2005 TAHOE DD
Old 12-21-2002, 12:52 AM   #5
bigjimzlll
bigjimzlll's Avatar
its a tray that bolts to the main bolts that keeps oil off of the crank...can add 10 HP for around 20 bucks(actually dosent add, but saves the HP)
Anderson,CA
Old 12-21-2002, 12:58 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
4 bolt mains are great if your gonna spin the snot out of your engine. If your making it a tow motor, then a 2 bol is fine. That engine will rarely see the high side of 3500 RPM.
Old 12-21-2002, 07:58 AM   #7
Gene
Gene's Avatar
I am guessing that the 3970010 came in both 2 bolt and 4 bolt mains because mine is a 4 bolt.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 12-21-2002, 08:35 AM   #8
crazy longhorn
Yes, the 3970010 came both with 2 or 4 bolt caps. My 383 is built in a 2 bolt version.......gotta use those 10/20 blocks whenever you find them
Old 12-21-2002, 08:48 PM   #9
robby
Semper Fidelis
robby's Avatar
I had a 69 300 horse 350 with 186 small chamber big valve heads that was two bolt main in a chevelle I had when I was in the Marine Corps, everybody I beat never knew.
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 12-21-2002, 09:46 PM   #10
RACING29
THats all you need(2 bolt main) unless your going over 600-700 horsepower. We have a 2 bolt block with good pistons and stock X rods with a cast crank and turn it 7200 rpm 30 laps ever weekend!
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
Old 12-21-2002, 10:24 PM   #11
nu2-72
What can anyone tell me about the 3970014 blocks ?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 12-21-2002, 10:44 PM   #12
mikep
Used to have a truck
mikep's Avatar
Chevrolet engineers and beancounters had absolutely no idea what they were doing when they specified 4 bolt mains and forged steel cranks in their higher load heavy duty engines. They did it just because they felt like spending more money on tooling, machining and extra parts. Car companies do that kind of thing because they like wasting money. It had nothing to do with increased bearing life . They used to love it when a customer would bring a seized engine in to be replaced. Gave the guys at the dealership something to do.
No truck :-(
mikep is offline   Reply With Quote
Old 12-22-2002, 12:29 AM   #13
bigjimzlll
bigjimzlll's Avatar
yea Mike..I know that was tongue and cheek, but sometimes you have to wonder what they were thinking with the 307 or torque swirl heads or the 2.8
Anderson,CA
Old 12-22-2002, 12:52 AM   #14
mikep
mikep's Avatar
Or that mini blazer in general. Especially the 5 speed manual trannies. Never have seen one last very long. Things pretty went to hell after "Boss" Ketterings departure.
I will have to differ with you on the 307. It did everything it was intended to do.
No truck :-(
