03-30-2009, 12:44 PM | #1 |
Parts Identification Please (w/pics) part II
Ok Guys heres a part here that I have never seen before and I do believe this to come from the factory. The first 3 pics are of a spring retainer that I found in a 1968 3/4 ton a.c. cab. It was mounted with that screw behind the passenger door where the the gas tank is. there was actually a circular indentation in the cab where the screw was mounted underneath the striker plate, I was thinkin maybe it was to hold a fire extinguisher???? The 4th pic I know is transmission linkage but is it to an automatic with column shift or standard transmission linkage?? theres an "L" on this piece also Thanks guys MIke __________________ 1967custom
1967custom |
03-30-2009, 12:46 PM | #2 |
Resident Curmudgeon
Re: Parts Identification Please (w/pics) part II
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-30-2009, 12:47 PM | #3 |
Resident Curmudgeon
The 4th pic looks like it may have been the rod from the zbar to cluch fork on a manual tranny that someone bastardized for another purpose?
03-30-2009, 12:48 PM | #4 |
Under Construction
IIRC,The spring retainer was for the Jack . The linkage does not look like an auto to me, so it must be linkage for a manual.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-30-2009, 12:48 PM | #5 |
Old member
The first 3 pictures are for the jack hold down behind the seat on passenger side I know. The other I haven't a clue.
03-30-2009, 01:00 PM | #6 |
I would have never guessed for the tool bag, I got the nount for the jack also with the spring as the tab on mine is broken. I found the z bar underneath a 69 chevy with a manual trans but I wasnt sure if it actually came from that truck
1967custom |
03-30-2009, 03:28 PM | #7 |
sufficiently talented fool
Fourth pic is a piece of an automatic trans linkage that goes from the trans to the frame. The one on my '72 is different, but that one looks like what is on my Impala.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
03-30-2009, 06:50 PM | #8 |
Who's got steelies?
4th pic looks like a 73 and up auto trans linkage. This would be the part that goes between the trans. and the frame mounted pivot.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
