View Poll Results: poly or oem rubber body mounts
poly mounts, hard like rock. 12 60.00%
rubber mounts, lasted long enough. 8 40.00%
Voters: 20. You may not vote on this poll
Old 03-30-2009, 01:48 PM   #1
RED72blazer
urban fourwheelin
RED72blazer's Avatar
poly vs. oem rubber mounts.
I want to here from you guys that replaced your body mounts. Did you use poly or oem rubber? if you had to do it again would you make the same choice? Do you wish you had gone with rubber or vice versa?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 03-30-2009, 02:35 PM   #2
RckyMntnKng
RckyMntnKng's Avatar
Re: poly vs. oem rubber mounts.
Really like my new polys...feels firmer and last longer haha
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 03-30-2009, 03:11 PM   #3
Burt4x4
Burt4x4's Avatar
installed poly back in 94 never had an issue..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-30-2009, 03:22 PM   #4
bsgmcc20
Im afraid of purple hangers..
bsgmcc20's Avatar
Ok so its 1987 and we are in new york building an old NESEG truck into a 4x4. We didnt have the money at the time. So we had Hockey pucks laying around. Hmmmm Body mounts drill and insert. They lasted 4 years.
I try it a few years ago and they lasted 6 months. So i installed Poly and they have been in for along time now.
Its all in what you want to do?
bsgmcc20 is offline   Reply With Quote
Old 03-30-2009, 03:55 PM   #5
RED72blazer
urban fourwheelin
this thing will not be wheeled hard. Mostly snowy logging roads and the occasional mud pit. Imagine it's 1972 and you are outfitting your new Blazer. i'm going to go with skinny tall tires. I don't want it to ride hard.
Also I should mention I have the poly kit already, but it doesn't have bolts.
Old 03-30-2009, 04:08 PM   #6
bsgmcc20
bsgmcc20's Avatar
Fire up the poly kit and put her in. Anti seize the bolts or get some poly lock bolts so if you twist and break one you can get them off if your out in the bushes.
sounds sweet
Old 03-30-2009, 04:09 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've heard positives about both. Personally, I'd probably go with the rubber to help smooth the ride as much as possible since I won't be wheeling. If I was building a crazy, hard-core machine like Burt's, I'd probably install the tougher poly mounts. I've also read here on the board you need to coat the poly mounts with something to stop them from squeeking
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-30-2009, 04:56 PM   #8
Burt4x4
Burt4x4's Avatar
Poly-Sqeeke
I have heard about it but never heard it
The main reason is the EnergySuspension poly I bought (black) were impregnated (sp?) some king of poplygraphite..I would have to look it up to get the proper term, some kind of anti-squeeke process Energy Suspension does. I think the red color is pure poly and may be the source of sqeekey mounts.
Old 03-30-2009, 06:06 PM   #9
cparman
sharp as a marble
I agree with Bouncy, I do not like poly anything. The rubber mounts work just fine, and allow someone else to wonder what that noise ( suspension bushings ) or what that vibration is. I want a Blazer/C-10 that drives like my wifes new Lexus, not like a race car. Ok, so I am dreaming a bit, but you get the picture.
cparman is offline   Reply With Quote
Old 03-30-2009, 07:14 PM   #10
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
If you go poly, you must grease them before installing, or they WILL squeak! But they will firm up the body mounts!
Jason
Cap'n Hook is offline   Reply With Quote
Old 03-31-2009, 05:26 AM   #11
vtblazer
vtblazer's Avatar
Factory replacement rubber mounts are a much better fit IMO, made to fit the application.
A lot of the poly sets I've seen are thinner and more generic, I've used em but won't ever again after seeing/installing the last rubber set.
vtblazer is offline   Reply With Quote
Old 03-31-2009, 10:31 AM   #12
Jtrux
I'm a poor spectator
Jtrux's Avatar
Good to know, too bad I already installed the energy suspension poly's.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 03-31-2009, 10:39 AM   #13
snj8198
snj8198's Avatar
Jtrux- how did your install go? did you experience any of the issues VTblaze mentioned?
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 03-31-2009, 11:35 AM   #14
teamradrz1
teamradrz1's Avatar
I also installed energy suspension Poly in my Blazer and I haven't been able to drive it much but fitment was perfect and I've heard no squeeks.
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 03-31-2009, 01:11 PM   #15
RED72blazer
urban fourwheelin
I was waiting for VT to chime in.
my buddy offered to buy the poly mount kit, so I ordered rubber today from GMCpauls.
Old 03-31-2009, 02:15 PM   #16
farmboy4ever
poly is fine for body but go rubber for the springs. they allow for more flex. even on old snowy logging roads that little extra helps.
duct tape+bailing wire = trail fix
if it aint broke it will be
whoa hillbilly
farmboy4ever is offline   Reply With Quote
Old 03-31-2009, 04:29 PM   #17
litebulblsc
litebulblsc's Avatar
Do you know what brand polys you were running? The energy suspension ones sound to be good. Perhaps you got different ones that weren't as good?
litebulblsc is offline   Reply With Quote
