Old 03-30-2009, 01:51 PM   #1
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Question steering column diameter & spline count
Bought this from CPP http://cgi.ebay.com/ebaymotors/63-72...0744QQtcZphoto... And they have asked me this...."
We need to know the spline count and shaft diameter of the output on the steering column and also the steering box".
Can anyone help me answer this, or tell me where the splines are that I can count, and where the output is so I can try and measure the diameter.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 03-30-2009, 04:01 PM   #2
eightbanger
454 MAKES IT ROAR
Re: steering column diameter & spline count
It's a 71 with power steering & tilt....are the splines in the rag joint?
Nigel.
No more pain.
Old 03-30-2009, 06:53 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hello Nigel,
I believe you'll have to remove the intermediate steering shaft to get your spline count...here's a pic of the intermediate shaft.....you'll need to count the splines on the steering column and the splines in the steering box....I think?!?!?...hope this kinda helps Mate!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-30-2009, 06:56 PM   #4
eightbanger
454 MAKES IT ROAR
Thanks Geoff....your a pal. So is the intermediate shaft the flat sided one or is it the one that you have indicated in the second pic? I'm really dumb on this stuff.
Nigel.
No more pain.
Old 03-30-2009, 07:19 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
Sorry Nigel....I meant to say...The intermediate shaft connects the steering column to the power steering box (so it's the whole shaft shown in pic 1)....So you would need to remove the rag joint at the pwr steering box first, then back the bolt off the collar at the steering column (as seen in the second pic) to remove....you'll need to wiggle it off....be patient!HA
Geoff with a G
Old 03-30-2009, 07:32 PM   #6
eightbanger
454 MAKES IT ROAR
Ok! I understand it better now. Getting that question from CPP threw me, the way they advertise it I thought it fit right on there...silly me for thinking things were that easy.
Thanks for your help mate.
Nigel.
No more pain.
Old 03-30-2009, 07:39 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Nigel,
I'd recommend getting a Factory Assembly manual too it looks like this....it runs $35-$40.....check with Wes I think he has some....
It has some very detail assembly pics that helped me out tremedously throughout my build!!!
By the way, how'd your transmission fix turn out??
Geoff with a G
Old 03-30-2009, 08:08 PM   #8
eightbanger
454 MAKES IT ROAR
I'll pick one up.
Got the trans back the other day...going to update my original post and you can see how it came out. Basicly £400 on a general revamp of the Trans & £200 on a new Torque Converter which converts to about $850.
Nigel.
No more pain.
Old 03-30-2009, 08:32 PM   #9
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Originally Posted by eightbanger View Post
Bought this from CPP http://cgi.ebay.com/ebaymotors/63-72...0744QQtcZphoto... And they have asked me this...."Can anyone help me answer this, or tell me where the splines are that I can count, and where the output is so I can try and measure the diameter.
Your truck should be 3/4" diameter & 36 spline.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 03-31-2009, 03:58 AM   #10
eightbanger
454 MAKES IT ROAR
Thank you Kev, i'm going to take it apart and have a look as well, it will need to come out in the end to fit the new one anyway.
Nigel.
No more pain.
Old 02-29-2020, 08:47 PM   #11
DonLeverton
Originally Posted by gcburdic View Post
Hello Nigel,
Can you tell me what that intermediate shaft is off of?
I'm putting an early 70's G-Van column (3/4"-36 spline) into my 66 GMC.
The Steering box in my 66 is a Sagainaw 808 (3/4" - 30 spline) out of a 79 C20.
The intermediate shaft that came with the 79 looks just like yours, except it has a 1" DD at the top end of it, and a rag-joint coupling at the bottom end.
Yours looks like it's 3/4" - 36 spline at the top, rag joint at the bottom?
I really like that it's the collapsible style with the nylon pins.
DonLeverton is offline   Reply With Quote
Old 03-01-2020, 10:42 AM   #12
Andy4639
Old member
Andy4639's Avatar
Talking Re: steering column diameter & spline count
Here is my link to putting the tilt steering columns in my trucks. As stated 3/4" DD on the box end and 36 splines on the column end.
http://67-72chevytrucks.com/vboard/s...d.php?t=799703
Here is what I bought for the ramp truck.
Ensun 3/4"-36 Spline x 3/4" DD Nickel Plating Single Steering Universal U-Joint, Maximum Working Angle: 35° Degree, Total Length: 83mm (3-1/4")
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
