03-30-2009, 02:42 PM | #1 |
Active Member
72 Big Block - All or Part?
Original Seat - no tears
$2500 - -Bought this Bad Boy several years ago. Let it set for about a year and then started working on it to put it on the road. Couldn't find the title to change it over and register in my name. Got hold of the guy I bought it from to get a replacement title and he said he wouldn't help. So, it has sat behind my shop for about 5 years growing mold and raising squirells. It is a Cheyenne Super 20. Big Block, 4 speed, tilt wheel. Has the original seat in nice shape. Might be dry rotted? It ran, barely, when parked. I think it had some valves burnt. Someone before the guy I bought it from had a fender bender(white driver fender) and got mad and made a tank out of it. He extended the front and rear bumpers with some massive steel. Cab is solid, rockers are starting to go. Cab corners and floor are good. bed is solid, has some rust from leaves stacking up, but no rot. Don't really want to part it out, so if someone can deal with the title issue, they can have a great project with everything there. If I can get $2500 for the whole thing I'll let it go. I'm sure the peices and parts would bring more, but I'll let somebody else worry about that. I'm in East Texas near Tyler. Buyer can worry about getting it home. What do you think? straight body - no rot original big block + squirrel nest good cab with solid corners and floors.
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
03-30-2009, 02:48 PM | #2 |
Formerly- 1972SuperCheyenne
Re: 72 Big Block - All or Part?
Man I wish you were closer. That thing would be in my driveway already. Please let me know if you decide to part it out. I am interested in the tilt plus shipping to 27523. Thanks and good luck with your sale, however I dont think you will need it.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
03-30-2009, 02:54 PM | #3 |
I might be interested in it. Can you pm me details on the title?
Thanks Todd
1978 Dodge Omni |
03-30-2009, 02:59 PM | #4 |
put me 2nd in line for the tilt if you do not sell it.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
03-30-2009, 03:02 PM | #5 |
Moderator
If you decide to part it, I would like the original air cleaner and stovepipe/heat riser setup. Shipping to 92503.
If you do not part it, good luck with your sale! |
03-30-2009, 03:10 PM | #6 |
Im afraid of purple hangers..
Im just going to throw this out there. time of orignal post permiting.
The Department of Motor Vehicles in most states, has a Purge Process that they do. If a vehicle has not had activity in 5 to 7 years. They remove the entry from the system. Now that does not mean its gone completely. It just helps you the present owner to get a title on the vehicle and put it in your name if you lost the title, or had a title issue. Hope it helps |
03-30-2009, 03:19 PM | #7 |
Under Construction
if you part let me know. I would be interested in the complete drivetrain, and clip....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-30-2009, 03:34 PM | #8 |
Can I get 2nd in line for the tilt column. shipping 77029 (Houston, tx)
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
03-30-2009, 05:18 PM | #9 |
Active Member
I'm going to let this run like it is for a few days. If no one wants the whole thing I willl think about parts. I didn't mention that the tail gate is not good. all the other body parts are useable.
Papa Smurf
03-30-2009, 05:42 PM | #10 |
You mean third.
03-30-2009, 08:12 PM | #11 |
How is bed floor and do you have a few more pics...? Sent you PM if you can forward pictures.
Thanks, Alan |
03-30-2009, 11:19 PM | #12 |
03-31-2009, 01:51 AM | #13 |
if you part, i would like all the clutch linkage. thanks, jake
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
03-31-2009, 11:36 PM | #14 |
ps stuff- lines pump,brackets,reservoir etc. not the gearbox though
alt. brackets, fan shroud if its the same as a auto one.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 Last edited by thelonerife; 03-31-2009 at 11:37 PM. |
04-01-2009, 05:30 AM | #15 |
I would be interested in the front grill and outer shell if parted out thanks
04-01-2009, 08:49 PM | #16 |
Active Member
Can't believe somebody doesn't want a good project. Lots of requests for parts, but I'm not ready for that yet.
Papa Smurf
04-01-2009, 11:09 PM | #17 |
I would be interested in the glove box door and door panels.
04-03-2009, 11:14 AM | #18 |
Active Member
ttt
04-03-2009, 11:31 AM | #19 |
if u part i would want the pedals and bed..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
04-04-2009, 08:29 AM | #20 |
Active Member
bttt
04-11-2009, 08:42 AM | #21 |
Active Member
One more time to the top. If there is no taker for the whole truck it's going under the knife. I hate to part out such a solid truck, but it seems the market is not there right now.
04-11-2009, 10:24 AM | #22 |
Try putting it in the 'trucks for sale' section on here. I look there for complete vehicles sometimes. This looks like a great project to make it a short bed with big block. I wish you were closer too, because you don't see many trucks in this good of shape around here. Good luck with it. This would make someone a great project!
04-11-2009, 10:47 AM | #23 |
still interested in the tilt wheel
