Old 03-30-2009, 07:19 PM   #1
Grapdawg
Driven a 72
Grapdawg's Avatar
Heater Core question.
On the heater core does the top hose go into the intake and the bottom to the waterpump or is it vise versa. I have looked at several pictures and have seen them hooked up both ways. I live in Minnesota so it is gunna have to get hooked up if im gunna use her as a daily driver. Anywho thanks for any help.
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 03-30-2009, 07:33 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Heater Core question.
It works either way but one is 5/8 and the other is 3/4 so if they match.....I put my heater core in upside down because I didn't like the hoses crossing.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-30-2009, 08:36 PM   #3
Grapdawg
Driven a 72
Grapdawg's Avatar
Thanks I kinda figured as much. But wouldnt the coolant be hotter coming out of the waterpump? Probly not but just thought I would ask since I live in mn and need it as hot as possible. Thanks again.
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 03-30-2009, 08:53 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
The hot water return is from the top of the engine & going to the top of the radiator, the cool water is circulated from the bottom through the water pump.
The trucks with automatic transmissions had the return line going directly to the top of the radiator from the heater core.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-30-2009, 09:18 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
s/t
I hate to hi-jack this thread but I'm going to due to an issue this brings up in my truck. I get very little heat out of my heater and although I haven't checked my thermostat, I wonder if this might be why I'm not getting heat based on the routing you've described? I have an automatic.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-30-2009, 09:18 PM   #6
Grapdawg
Driven a 72
Grapdawg's Avatar
Yep sounds right to me thanks for the info as always. Never fails, got a question and it will be answered.
Cheers
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 03-30-2009, 10:18 PM   #7
Sport/Truck
Sierra Grande Club
You can plumb the return back into the water pump, that is how the manual transmission trucks were set up. Either will work.
s/t
Old 03-31-2009, 04:03 PM   #8
gary2232
Ok I have a related question. 72 automatice trans with A/C Heat always on. I have the vacumme controled valve in heater hose that is new but is not closing? But hot water is alway flowing I think through core. Is this wright??
gary2232 is offline   Reply With Quote
Old 03-31-2009, 04:40 PM   #9
Sport/Truck
Sierra Grande Club
You should be able to connect it to a known vacuum source and watch it close. If so then it’s up stream on the vacuum side especially since you said the valve is new.
s/t
