Old 03-30-2009, 08:58 PM   #1
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
lock cylnder stuck?
i turned the key to acc position, push the pin in, but i cant pull the lock out? and to make matters worse the key doesnt stay in the lock, so i cant pull on it while i push in the pin. any tips? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 03-30-2009, 09:03 PM   #2
spinning wheels
spinning wheels's Avatar
Re: lock cylnder stuck?
Can you try it with another key? Sounds like your key is worn out. Just my guess.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-30-2009, 09:09 PM   #3
vasquezmrysvll
"the other guy"
the key still operates in the the lock, my problem is that i cant seem to get the lock cylnder out
Old 03-30-2009, 09:29 PM   #4
spinning wheels
OIC.... you mentioned that the key would not stay in to pull on it.
Try spraying WD40 around the lock. It may be stuck do to age. If all fails PM LocDoc on this site.
They usually pop out once you insert the paperclip into the hole.
Old 03-30-2009, 09:41 PM   #5
vasquezmrysvll
"the other guy"
got it apperantly you need to continue turning the key counter clock wise while pushing the pin,and the lock will pop out. thanks for the input and quick response.-vasquez
