Stepped trailing arms
I've searched all over and cant find any threads of anyone doing any trailing arms with a 2" step I've seen the adjustable, notched, boxed, blocked and the stock copies. So here I go... I've reverse engineered a set of stock arms and built in a 2" step and pinion correction for a 3" drop spring total 5" drop the miter cuts are all going to be beveled and welded with 7 ga. backer strips and doubler plates on both sides also 7 ga. One problem I'm running into is the mounting hole for the coil spring is rather close to the step and since my c20 has leaf springs I have no idea of the springs O.D. I'm planning on moving the front pivot 1" father since these wheels aren't centered any way and it would help with my spring clearance. Any feedback would be greatly appreciated.
#3 | |
Re: Stepped trailing arms
![]() Nice work! As for spring clearance, couldn't you 'trim' the upper portion a little more vs. it being square? If it was kicked back @ say 45° you'd gain a bunch of room from the looks of it. That would allow for more wiggle room should it be required, or.... switch to air bags ![]()
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-31-2009 at 12:11 AM. |
Thanks guys. Scoti I did toy around with various configurations and angled the riser piece but the limiting factor there was the first hole for the axle seat is only about 7/8" from the inside corner to centerline of hole. I've got room for a 6" dia spring if I extend the arm 1" forward I'll have room for an 8" dia spring or like you said bagg it
#5 | |
Happy to be here
![]() Join Date: Mar 2000
Cool piece. I agree with Scoti about more angle on the corners. It may not help the clearance issue but will look aesthetically better.
Then again, so would some cool holes along the length.
Thanks for the feedback I played around some more with angling the riser and its doable I would strap the bottom and just cap the top. I agree holes would look good I seen the ones bentfab built (those look amazing) too bad you cant dimple box tubing I thought about boring holes and lining them with some thin wall DOM or simply build them out of flat sheet cut outs which would be the best way. Here's a pic of the angled concept.
cool i like it
nickle and dime |
Option #2 'looks' better (flows better). Option #1 works good enough if it's all you can do for extra clearance @ each area of concern (spring OD & rear-end mounting pad).
Since you have one readily available, I've been trying to find the length of these arms w/o having to pull my rolling chassis apart to do so. If you wouldn't mind, what's the exact length from the C/L of the front bushing to the C/L between the u-bolt holes?
#10 | |
The dimensions I took from the stock arms are from CL of front mount to where the arm slops up is 45-3/8" from that point to CL of the first U bolt hole is 4" and the U bolt CL to CL is 4-1/4" |
i like the idea, makes me think again
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
Happy to be here
I'll take door #2 Monte...
#13 |
Door # 2 it is...
#14 |
Happy to be here
Much more pleasing to the eye...
#15 |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#16 |
Ohooooo . . .... ding, ding, ding, ding.... ding....
#17 |
I've got grease on my mind.
Another thought for the springs is look to the cars of this era (which is where GM got the idea in the first place) On the cars the spring is placed on top of the axle. Play with placement of the top mounting bracket for the ride height you are looking for.
#18 |
Unfortunately that doesn't help w/the amount of drop which is what everyone is usually after.
#19 |
Yeah my first car in high school was a 66 Buick Special it had trailing arms don't remember where the spring were but I did all I could to jack that rear end up to clear my tires was lots of fun.
#20 | |
The LuvShack Garage
![]() and Member fixit-p ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#21 |
Thanks Yo...Well I finally had some time to put my arms together today here's what they look like so far.
#22 |
Wow! Nice work. How do I get a set?
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
#23 |
#24 |
Those trailing arms look awesome! You do some really nice work.
#25 |
Better than nice!
