Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
LS1 Question
I PROMISE I tried the search function first. Does anyone know if the LS1 vette oil pan and accessories(including A/C) will fit in my 72 Super without the oil pan hanging down below the frame? I know the CTS-V oil pan works great (thanks to the posts on this great forum) But need to know about the Vette oil pan. All help is greatly appreciated. Thanks alot guys and gals.--Josh
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Always wrenching!!
Re: LS1 Question
the depth of the pan i don't see being the issue, its going to be the fins that kick out from each side of the vette pan. I don't know about this into a truck, but i have worked on many vette's and they are an odd shaped pan.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
Thread Killer!
Re: LS1 Question
Try here www.ls1tech.com
http://www.ls1tech.com/forums/conversions-hybrids-28/ There is a lot of info there. Good Luck.
71 Cheyenne SWB LS1 and auto. http://67-72chevytrucks.com/vboard/s...d.php?t=256470 _____________________________________ If it's worth doing, it's worth doing twice... _____________________________________ Don't Mistake Honesty for Negativity... |
Re: LS1 Question
My engine came with a vette pan and front accessories
The vette pan doesn't work The accessories will work. The A/C compressor is VERY close and I did just a little clearancing on the frame to get the refrigerant line to fit by. ![]() |
Parts and more parts
Re: LS1 Question
It is my assumption, from meetings with Mark Campbell at Street and Performance, that the Vette pan is not good for the truck layout. You will either want the Camaro pan or the GM truck pan for your install. If the truck is lowered the aluminum truck pan hangs pretty low and could cause a dragging issue. There are aftermarket pans made by Milodon and Moroso that fit these engines too. Theyare pricey, but are made of metal instead of aluminum and the pan does not hang as low as the GM truck pans.
#6 | |
Re: LS1 Question
Re: LS1 Question
Is there any way you could post a pic showing how far the Camaro oil pan hangs down? I would appreciate it. Also, what engine mounts are you using? Thanks
Re: LS1 Question
I did the LS1 swap in my 68' SWB stepside and decided to go with the Hummer oil pan and the alum. relocating motor mount bracket and had no problems.
![]() Join Date: Apr 2005
Re: LS1 Question
I used the CTsV pan. Here's a few pictures and a link to the different pans.
http://67-72chevytrucks.com/vboard/s...40#post2818040 OBTW, I used the ECE motor mounts. .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-31-2009 at 05:30 PM. |
