Old 03-31-2009, 11:32 AM   #1
71C10SWB
71C10SWB's Avatar
Question Steering Wheel Nut
When I got my truck ('71), it the top 2 or 3 threads was stripped off of the steering shaft and the nut was stripped completely.
I had a spare cab, so I went to look at the shaft on it and it was stripped too.
Is this a commin problem on these? Is there an easier fix than replacing the shaft?
I'm going over to my in-laws tonight. He has an old '72 in the woods. I'm going to chack to see what kind of shape the shaft is in on it.
thanks,
Brent
71C10SWB is offline   Reply With Quote
Old 03-31-2009, 12:21 PM   #2
haysonj
haysonj's Avatar
Re: Steering Wheel Nut
thanks,
Brent
You could try rethreading to the next smaller size (maybe metric) and get a new nut.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-31-2009, 07:50 PM   #3
I think you`ve hit a bad streak.I`ve never seen one stripped.
Old 03-31-2009, 10:13 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
my truck has a loose nut holding the wheel. I am still trying to figure out how to fix it.
sorry, I had to say it after seeing the title.
68C15 is offline   Reply With Quote
Old 03-31-2009, 10:30 PM   #5
KMACD71
KMACD71's Avatar
My 71 had the same problem when I recently changed the steering wheel. Nut was fine but the steering shaft had just enough threads left to tighten it down. My truck didn't have the original steering wheel so I'm guessing they get stripped when someone doesn't use a puller to get the wheel off.
KMACD71 is offline   Reply With Quote
Old 03-31-2009, 11:07 PM   #6
maddog1331
maddog1331's Avatar
lol took me a sec to get that one
maddog1331 is offline   Reply With Quote
Old 04-01-2009, 12:21 AM   #7
CSGAS
optomistic ah-so
CSGAS's Avatar
Have you tried checking the case to see if something's missing?
On the threads deal...there could be enough metal left to chase it with a same-size tap and even though it won't actually be fixed they may still be usable again. Is it the center that's messed up or the outer holes? In any case I agree you are more likely the victim of abused Chevies, not some common flaw.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
