03-31-2009, 12:28 PM | #1 |
Take the paint off of a chrome grille!
GAHHHH! Laquer Thinner, and now paint stripper won't take the paint off my chrome grill. What else can I do? How hard and what shoul I use to scrub? Any ideas? I want to see the CHROME!!!! This is the stuff I tried on it:
1982 K10 SWB 1987 V20 - Sold - Doh! |
03-31-2009, 01:07 PM | #2 |
Re: Take the paint off of a chrome grille!
IIRC Factory Grilles were not chrome. It was either painted or anodized aluminum. If you have a chrome bumper it is a repo. I have heard of using oven cleaner to remove anodized coating. Doug
03-31-2009, 04:38 PM | #3 |
Oh I see..... The G-M-C letters on it aren't chrome, the grille may be a repo. I still want to see whatever's under the paint!
03-31-2009, 04:40 PM | #4 |
Airport Bum
He has a GMC.
If stripper won't take it off, then thats some heavy duty schitt.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
03-31-2009, 08:58 PM | #5 |
Should I scrub with something harder?
03-31-2009, 09:11 PM | #6 | |
Try oven cleaner or naval jelly...... paint stripper should work but you might have to submerse the grill in it...... most strippers require you keep it wet for an extended period.
CHEVY ONLY Last edited by joe231; 03-31-2009 at 09:12 PM. |
03-31-2009, 11:51 PM | #7 |
Shloooooong bed member #2
[QUOTE=joe231;3231214]I'm pretty sure you could get chrome bumpers stock.....and some of the GMC's came with chromed steel grills.....
QUOTE] Your right Joe, My neighbor has a 65 GMC Custom. chrome grill, front bumper even has the trim around the door windows with the little custom badges. I went back and read your build thread and I may be wrong but your GMC letters look to be off of a newer model truck. and your bumper and grill may not be chromed, do you see any????look on the back side and see if you see any chrome at all..you may be spinning your wheels
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q Last edited by 4dranch; 04-01-2009 at 12:07 AM. |
04-01-2009, 03:12 AM | #8 |
Cantankerous Geezer
I usually use an SOS pad to clean chromed parts. You should be able to use steel wool with your stripper, but don't scrub too hard with it. You can also try the green scotch-brite pads. I just cleaned some this evening with glass beads.
Fred There is no such thing as too much cam...just not enough engine. |
04-02-2009, 10:11 PM | #9 |
I tried all of what you suggested, to no avail. Truly bada$$ paint. I've resorted to a razor blade to scrape the paint off. It works..... and there IS chrome under there! It looks pretty beat though.
I'd rather see beat chrome than fresh paint anyday though.
04-02-2009, 10:23 PM | #10 |
Daring to be Different
Why don't you just send it in to be chromed. They will strip the paint in the process.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
04-02-2009, 10:35 PM | #11 |
04-02-2009, 10:38 PM | #12 |
Yea I'm in the same boat. Take the paint off, primer and paint it with a light color. Rattle cans work for a small job.
04-02-2009, 11:08 PM | #13 |
Soda blasting will remove the paint and not damage the chrome. It will also not damage glass, rubber, anodized aluminum and plastic. I was amazed when I saw an entire van soda blasted without removing one piece of trim, glass or rubber...there wasn't a speck of paint left on the van when it was done.
04-03-2009, 08:42 AM | #14 |
Cantankerous Geezer
One thing I just remembered when stripping paint is that I use the paste style stripper that is not water soluble. Smear it on thick, cover and leave overnight. Trash bags make good covers, as does heavy plastic sheet. This helps keep the stripper moist and working. If it dries smear on some more fresh to loosen it up.
04-03-2009, 09:04 AM | #15 |
Phone's ringin Dude.
I'm not sure how the paint is on older chrome, but on my 72 GMC I used this stuff called Wenol, a rough shop rag, and a ton of elbow grease. I've got it about 3/4 done so far. Carb cleaner might work, too.
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
04-03-2009, 10:18 AM | #16 |
Here's something to think about. When chrome is painted over it should be sanded so the paint will stick. If they did do that it I wouldn't worry about saving the condition of the chrome.
04-03-2009, 10:33 AM | #17 |
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
04-03-2009, 11:29 AM | #18 |
Ooops! GMC. Sorry. I will STFU now.
04-03-2009, 02:25 PM | #19 |
Cantankerous Geezer
A good point. However, if the scratches aren't too deep they can be buffed out. You never know until you try.
04-03-2009, 02:40 PM | #20 |
Chrome won't buff out from sanding scratches. If it were aluminum it would..
04-03-2009, 02:43 PM | #21 |
I just got another idea. I knew a girl that could suck the chrome off a trailer hitch ball. Maybe she could suck that paint off your grill to the chrome if she doesn't suck too hard.
04-03-2009, 02:47 PM | #22 |
you ain't right
04-03-2009, 02:59 PM | #23 |
Being right isn't always funny.
04-03-2009, 03:00 PM | #24 |
Hey Y'all!!
I think I used to know her sister...
Just hopin' I live long enough to finish something!!! |
04-03-2009, 03:04 PM | #25 |
I might have to look up her daughter!
