Old 12-21-2002, 07:04 AM   #1
conman
Longhorn Bed
If I take a regular long bed and remove the front, then take the first section of a longhorn bed remove it can it be attached to the regular longbed? I have a longbed in great shape, but my longhorn bed isn't that good. Thinking a swap like this would get me a great bed overall.
Fayette Alabama
conman is offline   Reply With Quote
Old 12-21-2002, 08:46 AM   #2
crazy longhorn
Fabricate till you "puke"
You could probably do that, but will be in for quite a bit of welding & fitting. You may want to do a little measure, the longhorn bed is 6" longer than a long bed, but from the front edge to the seam, i beleive is 7". also, Im not sure if the placement of the box supports is the same. Good luck, & let us know how it goes
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-21-2002, 08:48 AM   #3
Mudder
Mudder's Avatar
My cab came from a long horn truck. It had no rust and now I'm wondering what the bed looked like. I know it had a lot of stuff pilled in it.
Mudder is offline   Reply With Quote
Old 12-21-2002, 10:14 AM   #4
busterwivell
If you need some quick crossmember measurements. my new (to me) Longhorn bed is in the yard upside down, with the crossmembers exposed for easy measuring. Let me know.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 12-22-2002, 01:27 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It would be quite a bit of work, but since it is butt welded together, and the stake pockets are not modified for the longhorn bed, it could be done fairly easily.
I just wonder if it would be worth the time/effort. I know of a decent longhorn bed for sale in Tx....100 bucks. Plus there are a few members selling them, I think one in PA and one in Nevada.
Just a thoguht.
