Old 04-01-2009, 03:22 AM   #1
enaberif
Engine Timing
What would you guys consider excessive timing on a stock 305 engine?
I've been playing around with my timing trying to get rid of a noise which I thought was a knock/ping from the timing being wrong but it hasn't helped.
But tonight I was playing around while driving and with only mechanical advance I have found a pretty sweet spot where the truck seems to be a lot more responsive on the throttle and overall driving.
I haven't had a chance to see what the timing is set at but I will tomorrow but I have a feeling its probably close to 12-14 degrees BTDC maybe more.
enaberif is offline   Reply With Quote
Old 04-01-2009, 03:59 AM   #2
mongoose
mongoose's Avatar
Re: Engine Timing
is your dist curved? what's total timing?
12 is a bit much for a stock motor.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-01-2009, 08:02 AM   #3
85Bowtie
85Bowtie's Avatar
Re: Engine Timing
Is it pinging/spark knocking when you get into it?
If not, your probably ok.
I could never go much more than 10-12 in my stock 305 before it would start detonating.
I think factory setting initially is 4-6.
If it does "ping" a little, the off-road 104 boost works pretty good to get rid of it.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 04-01-2009, 12:09 PM   #4
Damien
Damien's Avatar
Re: Engine Timing
A stock engine should run well on regular fuel. Timing should be 4-8 degrees. Check specks for sure. Could also be running lean or hot. check carb tuning and coolant level, water pump, ect.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 04-01-2009, 12:42 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Engine Timing
Are you still running the computer controlled distributor? After I put an HEI in my truck and eliminated the computer control, I typically ran my timing at 12 to 14 degrees BTDC on my 350 engine. now that I am running a stroker motor, I have timed my engine with a timing light that has an advance capability and I set the distributor at a "TOTAL" advance setting of 35 degrees.
piecesparts is offline   Reply With Quote
Old 04-01-2009, 01:35 PM   #6
enaberif
Re: Engine Timing
Never was computer controlled always HEI.
Running the engine at 8 degrees BTDC it just seems lifeless but where I have it now.. and will be checking in a bit it seems to really pep up.
I'm also going to be checking how true the TDC is too to make sure that isn't possibly out of whack too.
But perhaps 12-14 isn't so bad
Old 04-01-2009, 04:00 PM   #7
mongoose
mongoose's Avatar
Re: Engine Timing
get a spring kit..... get all advance in by like 2500.. then knock the timing back to 8..
Old 04-01-2009, 04:24 PM   #8
piecesparts
Re: Engine Timing
I was running a spring kit and also set the timing at 12 degrees, the truck ran real well, there. The more advance you can achieve the better the fuel economy.
Old 04-01-2009, 04:42 PM   #9
enaberif
Re: Engine Timing
I have a spring kit with blue springs already.
As well as I have an ajustable vac can. I'll need to visit Mopac to pick up a timing tape.
Really? How does that work?
I mean no matter what I've got some stupid knock or exhaust leak I can only hear when the engine is under load and only then.
I did a valve adjustment and they are fine so my next idea is I possibly have an exhaust leak which I'll be attempting to fix in a bit or I'll have to start running like 10w40 oil.
