Old 04-01-2009, 10:51 AM   #1
chevyfan87
torque management
what is it, what does it do, when did chevy start using it, and what does it hurt to remove it??
"tell ya what bub"
2000 gmc sierra 1500 4.3 4x4
too poor for the projects
chevyfan87 is offline   Reply With Quote
Old 04-04-2009, 04:40 PM   #2
chevyfan87
Re: torque management
nobody willing to explain? or nobody knows 100% for sure?
"tell ya what bub"
Old 04-04-2009, 08:03 PM   #3
truckdude239
truckdude239's Avatar
what is it?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-04-2009, 08:21 PM   #4
chevyfan87
at least im not the only person who doesnt know...i know it relates to weak shifting thats about it...
"tell ya what bub"
Old 04-04-2009, 09:58 PM   #5
bwood
bwood's Avatar
Here are some links from other forums:
http://www.edmunds.com/apps/vdpconta...1/pageNumber=2
http://www.fullsizechevy.com/forums/...how-works.html
Here is a link from the FSC forums on 4.3L upgrades in response to one of your otherposts.
http://www.fullsizechevy.com/forums/...02-4-3-v6.html
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 04-05-2009, 02:07 PM   #6
Joe67
67 is sold
I've had my torque management 100% removed for over 100K miles now without issue
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-07-2009, 05:23 AM   #7
combustion
Originally Posted by edmunds.com
Of the three trucks we tested on the dyno, only the Silverado produced inconsistent results that appeared curiously low across nearly the entire rev range. Most unexpected was a power spike just before redline.
Although the spike resulted in a peak of 297 hp at the wheels — about right for the rated 367 hp at the flywheel, once drivetrain loss is factored in — the Silverado's measured power appeared to be underachieving everywhere else in the rev range.
In fact, the Chevy produces significantly less power than the Titan for the duration of the dyno test until the Chevy finally surpasses the Titan's peak of 291 hp at the wheels.
As it turns out, the explanation boils down to an engine calibration strategy. GM calibrated the 367-hp 6.0-liter V8 to remain in stoichiometric "closed-loop" fuel delivery mode for 4 seconds after the throttle is floored. This fueling strategy helps keep emissions in check (and saves fuel) at the expense of reduced power — about 40 hp less at the peak. Once the driver lifts his right foot from the wide-open throttle position, the 4-second clock resets.
This explains why the Silverado's power is low everywhere on the graph right up to the jump in power right before redline. Corresponding to the expiration of the 4-second window, the jump in power is indicative of the engine switching to open-loop "power enrichment" mode. It is only when operating in this mode that the engine delivers its full rated power.
this should answer your question
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 04-13-2009, 05:39 AM   #8
nekkidhillbilly
started in the trucks with the 4l60e
nekkidhillbilly is offline   Reply With Quote
