Old 04-01-2009, 06:33 PM   #1
RckyMntnKng
RckyMntnKng's Avatar
TC 6" EZ Ride Springs.
Strange question, but....
How would you turn a set of 6" spring packs into 4" spring packs?
Can you remove a leaf or 2 and make it lower and still work well?
If not would anyone want to trade a set of 4" lift springs for a 1st Gen Blazer/Jimmy or even a Dana 60...For a brand new set of 6" Tough Country Springs front and back, never installed?
Thanks ahead for the advice.
71 Jimmy: D60/14BFF, 9"F/11"B Lift, 350-350-203-205, Crossover Hydro steering, Beadlocks, Tube stuff and the bottomless cooler
RckyMntnKng is offline   Reply With Quote
Old 04-02-2009, 09:13 AM   #2
Burt4x4
Burt4x4's Avatar
Re: TC 6" EZ Ride Springs.
I don't think it can be done..I could be wrong. I would think the main leaf in the pack is arched for 6" along with the additional leafs. I would assume some of the shorter leafs may be interchangable but the main leaf is not.
Also the springpacks are built to work togeahter. The packs you see with only 3-4 leafs are built with thicker leafs, the packs with 5-7 leafs have thinner ones. If you start removing leafs from the pack the pack become weaker. I have seen spring packs fail/break on the trail so makin them weaker is not something I would want to flert with.
.02c
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-02-2009, 10:11 AM   #3
RckyMntnKng
Yes started thinking about that...The arch will still be for 6" either way.
I read an article once in Peterson 4wd about taking out a bottom leaf to get more flex and a softer ride...thats where that thought came from.
Oh well, I guess I just need to be patient and find someone who wants to trade thier 4" packs for these 6" ones.
Thanks-RMK
Old 04-02-2009, 02:16 PM   #4
amullis
amullis's Avatar
I saw a guy who had done this on a late model full size blazer. He had converted from independant front to a solid axle. He wanted the height of an 8" spring but still wanted to get a good ride. He took a set of 10" lifted springs and removed the second spring in the pack. Acording to him it worked great and the ride was much better than he expected.
amullis is offline   Reply With Quote
