Old 04-01-2009, 11:09 PM   #1
S3B3AST
S3B3AST's Avatar
Need help removing window...
Im trying to remove the back window in my 71 cab, but Im having a hard time getting it out, along with the other windows...any ideas, how tos, or advice? Thanks
1971 Chevy 4x4 short bed fleet side
S3B3AST is offline   Reply With Quote
Old 04-02-2009, 12:10 AM   #2
blakeaz33
blakeaz33's Avatar
Re: Need help removing window...
I've taken several out and reinstalled them with the original gasket, just did this with my 68 to remove the cab with the lift I used. I'm guessing you want to save the gasket, old gaskets dry out and rip easily so if it is in bad shape you may need a new one. Start in one of the top corners and pull the inside lip of the gasket back while applying pressure on the glass, all you want to do is get the edge of of the gasket on the other side of the pinch weld and work your way across the top of the window to the opposite corner. You can use a hook tool or screw driver to help get it started, glass tools for this are plastic. Once you get the top edges out the rest is easy, the back is tempered glass and can take much more pressure than the laminated windshields before breaking. If your gasket is dry rotted and you're using a new one just cut it out.
blakeaz33 is offline   Reply With Quote
Old 04-02-2009, 12:29 AM   #3
S3B3AST
S3B3AST's Avatar
Sounds easy, what about the front window. The seal is reuseable if I don't damage it?
Old 04-02-2009, 12:35 AM   #4
blakeaz33
blakeaz33's Avatar
The front works the same way, start from the inside on a top corner and work across the top to the other corner. I would start with the back glass, the windshield will break much easier than the back glass - the windshield should come out easy if there hasn't been any type of sealant applied between the gasket and the pinchweld. Just take your time and don't push too hard, will work best if it is not too cold out also.
Old 04-02-2009, 01:23 AM   #5
S3B3AST
S3B3AST's Avatar
All right thanks bud
Old 04-02-2009, 03:02 AM   #6
chopper103in
chopper103in's Avatar
why try to reuse a 38 year old piece of rubber-----i say cut it out with a knife and buy new seals
69 chevy swb
2.5 in droped spindle with 1 coil cut--5 in dropped spring in rear
5 in dropped spring
307 repaced soon with 350
3sp on tree soon replaced with 350 tubo
06 monte carlo
94 chrysler town & country---198K
84 jag xj6
76 sportster---57 panhead
chopper103in is offline   Reply With Quote
Old 04-02-2009, 09:24 AM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I agree...You think they are good until you compare them to a new one or play hell trying to put the glass back in with stiff rubber. Its time and money well spent for new.
sneakysnake is offline   Reply With Quote
Old 04-02-2009, 04:13 PM   #8
S3B3AST
S3B3AST's Avatar
Did you know that one seal cost $200? seen one for less let me know, it should be new, your right
Old 04-02-2009, 04:36 PM   #9
Ram-Man
Ram-Man's Avatar
You can buy those for about $30 each from most suppliers. I say cut it out.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 04-02-2009, 04:40 PM   #10
Green Machine
Green Machine's Avatar
Check this out for example -
http://www.classicparts.com/1967-72-...ctinfo/01-133/
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-03-2009, 02:35 AM   #11
S3B3AST
S3B3AST's Avatar
Wow did I read that price wrong. thank you guys
