Old 05-16-2002, 09:11 AM   #1
GMC1967
Post sm420 tranny problems
My 4spd tranny worked fine before I took it out of my truck for a new clutch. But since putting it back in it won't shift into reverse, anyone run accross this problem before? All I did was remove the cover w/ the shifter, and then put it back, on. Could something maybe have come out of alignment? All the other gears work fine.
1967 GMC Custom 8ft Fleetside 292 L6, 4spd.
1973 Oldsmobile Delta 88 Convertible 455, TH 400
1969 F#$% Bronco 302, 3spd 4.11's
1958 Oldsmobile Super 88 Fiesta Wagon
GMC1967 is offline   Reply With Quote
Old 05-16-2002, 10:03 AM   #2
Blazer1970
Blazer1970's Avatar
Post
I would guess that you did not get the reverse shift fork engaged properly with the gear when you re-installed the cover on the tranny. As I recall, this would be pretty easy to screw up.
Blazer1970 is offline   Reply With Quote
