04-02-2009, 07:06 AM | #1 |
skips 65k hei
anyone using Skip Whites 65k hei long enough to give an opinion on it
04-02-2009, 07:30 AM | #2 |
Under Construction
Re: skips 65k hei
just got mine in, so i cant give a opinion. but he got rave reviews on his other distributors from many board members.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 04-02-2009 at 07:31 AM. |
04-02-2009, 07:41 AM | #3 |
Under Construction
Re: skips 65k hei
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
04-02-2009, 07:46 AM | #4 |
Re: skips 65k hei
kind of mixed opinions
04-02-2009, 07:59 AM | #5 |
Under Construction
Re: skips 65k hei
5-year warranty.... several boardmember running them. im sure more will chime in....
04-02-2009, 01:24 PM | #6 |
Re: skips 65k hei
I put one of those my last project. It ran like a swiss watch.
04-02-2009, 01:26 PM | #7 |
Re: skips 65k hei
Good, I just ordered mine, should be getting it tomorrow.
04-02-2009, 11:15 PM | #8 |
Re: skips 65k hei
cool orderd one today
04-03-2009, 12:13 AM | #9 |
Re: skips 65k hei
Mine works great, it's been in my truck for a year and a half -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
04-03-2009, 10:46 AM | #10 |
Re: skips 65k hei
I have been checking out my wiring and trying to come up with a game plan while Im waiting for my dizzy to come. Im assuming the white connector on the fire wall is the ressitor ballast, so im wondering if I can take that out all together or does it serve another purpose, im thinking that I can run my 12g wire from the dizzy throught the fire wall and straight into my ingnition swich, and take out the wire that is there now and replace it with the wire comming of the hei,
04-03-2009, 11:11 AM | #11 |
Re: skips 65k hei
I put a small cap one from him in mine and it is working fine. The first one I got was damaged in shipment and I called them and had no problems returning it. They shipped me a new one and paid shipping both ways.
04-03-2009, 02:29 PM | #12 |
Re: skips 65k hei
Been checking out the wiring while waiting for hei to come in the mail, I have a wire that comes out of the fire wall and into, what I think is a ballast resirtor, and from there goes to the coil, then the other wire on the coil goes to a little canister on the side of the coil and dead ends there, the yellow wire on the silinoid is hard to trace but does not come back up to the coil, here is what I am assuming please correct me if Im wrong. The wire that comes out of the fire wall should be 12v and is connected to the ballast resistor if I connect straight into that wire and discard the ballast resistor I should have constant 12v and thats it, Im also wondering if some were along the line that yellow wire on the silinoid was disconected and I dont currently have the 12v at crank, possibly had a hei at some point and then back to the points and did not get rewired correctly
04-03-2009, 04:37 PM | #13 | ||||
Union Electrician
Re: skips 65k hei
1. it is not big enough to carry the proper current rating for the new HEI. 2.the wire is resistive type and will not let the HEI work to its potential. I have the 65K HEI from Skip White in my 69 driver and have had it in there for well over 2 years and it has worked flawlessly the entire time.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
04-03-2009, 07:48 PM | #14 |
Re: skips 65k hei
ok, after further investigation and replacment of a bad multimeter here is what I found, the wire comming off of the silanoid runs up to the ballast resistor and is 12v constant then on the other side of the ballast the wire is 9v and that goes to the coil, I origanly thought the wire comming to the resistor was straight from the ingintion swich, so can I run the 12v source thats comming of the silanoid to the hei as my 12v source,
04-03-2009, 09:07 PM | #15 |
Re: skips 65k hei
i installed one in my truck with the help of a friend and never could get it timed it only wanted to run at like 17 degrees advanced. i think he was installing it wrong so i ended up putting the points disabtor back in
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-03-2009, 09:08 PM | #16 |
Re: skips 65k hei
btw the yellow wire is 9v resistor wire . i ran mine with a inline 30 amp fuse from the fuse box switched source.
04-03-2009, 10:10 PM | #17 |
Re: skips 65k hei
I just bought one but failed to mention its for my 72 4x4 and just by looking at it, I can tell it will be rubbing on my firewall, so I too will just use points distr
04-04-2009, 04:01 PM | #18 |
Re: skips 65k hei
just pulled it out of the box, Holly cow that thing is huge, I have 6" from the edge of the old cap to the fie wall and 3" to the air cleaner, I think it will be fine. Couldnt drop it in today after preparing everything to be pulled the weather finnaly drove me inside
