Building Dreams out of Dimes!
Anyone running bed mounted batteries or fuel cell?
Hey guys I was wanting to throw some weight to the back of my truck to maybe even it out a little more.
I'm thinking of mounting duel batteries under my bed as close to the tailgate as I can get. Has anyone else done a similar modification like this? Also I would like to remove the two side tanks and put in a few cell. However I dont want to cut a whole in my bed. I would like to be able to use the original gas doors on each side of the bed so when I pull up to a gas station it doesn't matter what side I'm on. Well... Anyone got any advice before I get started...? |
Re: Anyone running bed mounted batteries or fuel cell?
If your wanting more traction, get you some intubes cut them in half, and fill with sand. You can take them out if you need to haul something. Just a thought.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
Happy to be here
![]() Join Date: Mar 2000
I would look up forum member Fuel Cell Guy and have him build what you want-LINK www.aluminumfuelcell.com
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 04-02-2009 at 07:59 AM. |
In my younger years i had a 80 elcamino with a 305 from a monte carlo and a 3 speed manual tranny! I thought it was a race car so i had a 15 gallon harwood fuel cell and 1 battery mounted in the bed! It was a pain I burned through my positive battery cable on my headers. It was an easy fix after I had it towed home but when it happened on a dark rainy night it wasnt so easy to diagnose! Thats a good idea using your fuel doors bacause climbing in the bed everytime you need to fuel up is not fun either. If I only knew half of what I do now! Good luck I know this isnt too much help just thought I would share my story with you remember to route that power wire away from problems!
A Blazer tank and relocated fuel door has been done. That way your box is still usable. I wouldn't put the batteries behind the axle. Water or road debries could get thrown up there and cause corrsion or worse. I would put them in front of the axle. You would still be moving weight towards the rear and off the front end.
I can still count my vehicles on two... wait three hands. |
#6 | |
6.0 powered square
my truck has a battery mounted inside the bed, in front of the driver side wheel tunnel, I would go with fuel cell or blazer tank in between the rear frame rails, and mount the filler behind the license plate, like mentioned
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
