12-21-2002, 06:59 PM | #1 |
circuit board for tach dash install
im getting ready to install a new circuit board on my tach dash on my 69 cst swb. i need pro tips from guys that have done this . examples what size bulbs go in and what to do and not to do. my blinkers do not work on my old one im hoping if i put all new bulbs and clean it all up it will all work. any tips are greatly appreciated. thanks in advance. DAN
1969 cst swb 350/400 th . DANNY C . ["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!! 1969 cst swb corvette hugger orange with 400 hp sbc I started out with nothing and i held on to it |
12-21-2002, 07:52 PM | #2 |
Factory dash lamps were #194 (2 C.P , Wedge type base) these lamps also used for the side marker lamps.
I prefer the #168 ( same type as 194 but is 3C.P) so is a brighter lamp.... no problem for dash lamps being brighter as the brightness can be controlled with the light switch. The brightness is there if you need it !....... I also replaced the #194's used in side marker lamps with the 168# an improvement, I would say...... Have diagramsn for the dash panel circuit board , if I can be of further help.........../Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
12-21-2002, 07:56 PM | #3 |
circuit in dash
jim, thanks so much im going to go get those bulbs before i install my circuit board. thanks , DAN
12-22-2002, 02:58 AM | #4 |
JIM -- I SURE WOULD APPRECIATE YOU EMAILING ME A COPY OF THE WIRING DIAGRAM. I PARTICULARY INTERESTED IN THE COLOR CODE OF THE WIRES IN THE CONNECTER. (WITCH ONE DOES WHAT)
THANKS JOHN AT FK9U812@AOL.COM
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
