Old 04-03-2009, 12:52 AM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
700R4 shift slots
I'm new to the whole 700r4 thing, and am curious, will it still have only 3 shift points for the shifter? Or do i need a shifter with 4 slots? If it helps, the tranny does have the electric lockup thing.
My current assumption is that a shifter with 3 slots will work fine. When it's in 3rd, the tranny will be able to shift to 4th assuming the switch is engaged. is this correct?
IvelDesigns is offline   Reply With Quote
Old 04-03-2009, 05:59 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 700R4 shift slots
it'll be fine. you won't be able to manually select 1st though.
MAKE SURE THE TV CABLE IS ADJUSTED CORRECTLY! unless of course you enjoy wasting time and money.
www.bowtieoverdrives.com
68C15 is offline   Reply With Quote
Old 04-03-2009, 09:33 AM   #3
MrC1
Dork For Days
MrC1's Avatar
It will have 4 notches from 1st thru 4th . It's just that your pointer won't line up correctly with the PRND21 indicator. You can buy a replacement that shows PRND321.
...or did I misunderstand the question?
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 04-03-2009, 09:44 AM   #4
IvelDesigns
nope, that's my question. but now comes the shifter... i picked up a B&M t handle shifter (used, so i only have the shifter, not the housing with indicator).
so with that said, i basically will have to pull up the handle to get into neutral? That's ok with me if that's the case. I'd rather that be the case than have a chance of the shifter getting pushed into R while moving forward.
btw, on this shifter, any idea why park has two notches?
Old 04-03-2009, 10:29 AM   #5
Hart_Rod
Hart_Rod's Avatar
Astro van columns work great in these trucks (late 80's early 90s). You get the tilt, dimmer and wiper all on the column. That's what I used in my 48 anyways.
Hart_Rod is offline   Reply With Quote
Old 04-03-2009, 05:09 PM   #6
Boog
laying low
Boog's Avatar
Does the Astrovan column have the gear indicator on it too? You wouldn't by chance have a pic or two of one installed in our favorite trucks would you?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-03-2009, 06:40 PM   #7
bigbadchev72
People know me
bigbadchev72's Avatar
The "slots" are in the transmission itself, not the shifter, Depending on what shifter you have you can get a new indicator for it.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 04-03-2009, 08:21 PM   #8
Hart_Rod
Hart_Rod's Avatar
No indicator. Here's a picture of it in my 48.
True....
Old 04-03-2009, 08:48 PM   #9
Boog
laying low
Boog's Avatar
I have always liked that truck Rob. The column looks good in there. Thanks.
Boog
primer is finer
