Old 04-03-2009, 11:17 AM   #1
tim21391
tim21391's Avatar
Thumbs up opinions needed
so im nearing the stages of body filler and primer on my cab and front clip... i wanna know if i get the cab mounted and fenders on and everything primed.. if it is bad to drive the truck like that for a week... i just wanna be able to drive it a bit because i havent drove it in almost 5 months... then after a week start sanding primer and paint it... bad idea or what?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-03-2009, 11:48 AM   #2
justin26
Re: opinions needed
no it will be fine to drive it as long as you want to i let my car sit for three years before i painted it and also drove it awhile too so you are good to go
justin26 is offline   Reply With Quote
Old 04-03-2009, 12:51 PM   #3
tim21391
tim21391's Avatar
Re: opinions needed
i just wanna drive it because if it sits like it has trans leaks from the speedo cable. so once i drive it it solves that problem... so thats why i asked.. thanks
