Old 04-03-2009, 03:53 PM   #1
morgan71
where to buy 14bff rebuild kit
I just bought a 14 bolt ff and dana 44 from a 3/4 ton chevy. Dont know what year as they are out of the truck already. My question is where is a good place to buy rebuild kits for these axles, also will have to relocate spring perches and shock mounts so where is a good place to find those also? These are going into my 67 GMC 3/4 ton project. Thanks for any help!
morgan71 is offline   Reply With Quote
Old 04-04-2009, 09:49 AM   #2
Dooley
Dooley's Avatar
Re: where to buy 14bff rebuild kit
www.drivetrainspecialists.com
Been buying parts from them for 25 years with no problems and excellent prices.
Dooley is offline   Reply With Quote
Old 04-04-2009, 04:53 PM   #3
LONGHAIR
It "depends" upon what you are calling "rebuild" kit? What parts are you looking to service? If you are just talking about brakes/wheel bearings/etc. you can probably get that kind of thing locally just as easily as anything else...
If you are talking about "internally", you may need to step back and evaluate things a bit more first. You cannot simply disassemble the differential (ring/pinion) and replace the bearings. It is just not that easy.....Besides, if the bearings are that worn, the gears are in bad shape too....and that is a fairly major thing.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-04-2009, 05:26 PM   #4
morgan71
As I said these are from a salvage yard , I know very little about there condition and want to rebuild them completely. But when I said rebuilt kit I meant internally as these are the only "kits" I know of. I am not new, have been building cars for 15 years, so I know what has to get done when swap out gears. I was looking for advice on where to buy an master rebuild kit, gears are fine wont be replacing those.
Old 04-04-2009, 05:27 PM   #5
morgan71
I found a 14 bolt swap kit at ruff stuff, they have the perches, shock mounts that I will need.
