04-03-2009, 04:20 PM | #1 | |
Best solution for a jack???
My question is, is a bottle jack the best solution to replace the original jack kit, for lifting both the front and back? If so, what is the max lift height I need if I lift from the recommended lift points (such as lower A frame support in front, if I recall correctly)? Here is a great thread with pictures of the original kit, and it states that the jack is 16" raised. Does that sound right? http://67-72chevytrucks.com/vboard/s...highlight=jack
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 04-03-2009 at 04:22 PM. |
04-03-2009, 04:32 PM | #2 |
Re: Best solution for a jack???
the clearance under the aa frames with a flat is less than 6inches the same thing with trailing arms or the axel tube so a bottle jack would need to be used on the frame rails which are alot higher than most bottle jacks//what i always carried was the cheapo $20 floor jacks stored in back of the seat// those are chancy at best but in an emergancy situation can usually get the wheel off the ground to change , always carry a can or two of instaflat stuff
04-03-2009, 04:35 PM | #3 |
Between Trucks...
I have a bottle jack. I lift under the trailing arm or a-arm, it only has to go up a couple inches.
Beat it to fit, Paint it to match... |
04-03-2009, 04:51 PM | #4 |
I have a 1.5 ton floor jack I carry. It has it's own little case to keep it under control. When the 70 becomes road worthy I'll move my floor mounted box with the tools and jack to it. I also carry a small piece of wood to sit the jack on.
I currently keep in the 70 the bottle jack that came with my 2002. They are close to the same size as the original and the jack rods store nicely in a case. You might find one in a junkyard on a trashed out truck. The bottle jacks from the newer (2003 & up) Dodges and GM trucks are almost identical, so you can widen your possibilities on finding one that way.
04-03-2009, 04:54 PM | #5 |
Bottle jack for me as well. That's what I kept in my 67' thru the 80's and now I keep it in my 68', along with a 12 " 2x4 for soft ground.
68' SWB 355 CID since 1987 89' S15 4WD 4.3 08' VTX 1300R 08' Chevrolet HHR (Wife's ride) "That man right there is the best sprint car driver in the whole ---damned country!" 1974- Indianapolis- AJ Foyt pointing out Jan Opperman in the garage. |
04-03-2009, 05:10 PM | #6 |
how about with a flat tire does it still fit?
04-03-2009, 05:16 PM | #7 |
laying low
I have a scizzor jack bought from GM. It goes down to about 3 or 4 inches high to 16 or 18 or so. Stores easy enough too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-03-2009, 06:25 PM | #8 |
i would not use it inless u are going to put a new tire on it.most shops will not piug a tire if u have used it in there.
But with tire slime i have always had good luck with it |
04-03-2009, 06:26 PM | #9 |
Between Trucks...
DOH, good point. I'll have to check on that.
