Old 04-03-2009, 07:03 PM   #1
Grapdawg
Driven a 72
Grapdawg's Avatar
Noisy lifters? Need help Please
Ok I have finally started driving my truck and It was sitting for 2 years prior to me purchasing it. At first when I got her running there wasnt much noise coming from the motor. But today I drove it about 70 miles and she started ticken alot. It had a slight tick before but now its pretty loud.
I was woundering if you all had any experiance with noisy lifters and ever tried to tighten the rocker arms to cure the problem. I know the motor is very tired and I need a new one but was hoping to make it through the summer with this one. I was thinking of trying to tighten the noisy lifters. (Take of driverside valve cover and see what I can find with it running anb see if I cant get it to quite down) What do ya think?
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 04-03-2009, 07:23 PM   #2
heavy70
heavy70's Avatar
Re: Noisy lifters? Need help Please
How much oil pressure do you have?
heavy70 is offline   Reply With Quote
Old 04-03-2009, 07:26 PM   #3
fine69
fine69's Avatar
After sitting awhile lifters get gum(varnish) on them. And will stick.
Change the oil then replace a quart or two of oil with tranny fluid(or Marvel Mystery oil) then run it for awhile.
This should fix the issue.
I have done this many times with great success.
Few years ago i bought a 67 Mercury Cougar. It had sat for 33 years not running. Motor was stuck. I MEAN STUCK. Took me 2 months to get it really turning over. Took the carb off, dumped tranny fluid strait down the intake. Let it soak.
Finally got it running. Did exactly like i told you to do. NO issues.
Unless you think your valves may need adjusted. Then its a different issue.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 04-03-2009, 07:47 PM   #4
Grapdawg
Driven a 72
Grapdawg's Avatar
I dont have a oil pressure gage, Wish i did.
I think its a varnish issue, I replaced the intake and had the exhaust manifold off I was able to see the valves through the exhaust ports abd a few were very varnished. Im gunna try the tranny fluid thing. Do I substitute quart for quart then?
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-03-2009, 08:00 PM   #5
vectorit
What?
vectorit's Avatar
Are you sure it's a lifter? How do the exhaust gaskets look, and have you tried seeing if any of the exhaust man/header bolts are loose at the head? If stock, does it have the original heat valve in the down pipe? Sometimes the spring gets lost/broken, and the valve will tick when it's just floppin around with the exhaust gases goin by.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-03-2009, 08:04 PM   #6
Ricks1971
Ricks1971's Avatar
This is the only product I will use. They use this stuff in the motors on big ships. I just started a 70 pick-up that had not been started in 9 years. I changed the oil and the lifters were still making noise added 1 pint of sea foam and no lifter noise! GREAT STUFF!
http://www.seafoamsales.com/motorTuneUp.htm
Ricks1971 is offline   Reply With Quote
Old 04-03-2009, 08:14 PM   #7
Grapdawg
Driven a 72
Grapdawg's Avatar
No I dont think its the exhaust. It has stock manifolds and I just replaced the gaskets. i also checked them to insure they were tight. It is definetally a lifter type noise. If ya take off the breather cap and get close to the hole you can really hear thr noise. As for the sea foam I have use it before. Maybe I should try it first as I just changed the oil not to long ago and would hate to waste the money. So put the seafoam in the oil or the gas or both?
1996 GMC JIMMY
1972 CHEVY C10 LWB
Old 04-03-2009, 10:24 PM   #8
big mike71
big mike71's Avatar
Start it and pour some marvel mystery oil down the carb it worked on my chevelle.
big mike71 is offline   Reply With Quote
Old 04-03-2009, 11:35 PM   #9
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
I do love this stuff also.
Mine started ticking on me after I bought it, I tried seafoam.. cleaned the carb. I ran it twice through with oil changes, tried different weight oil, marvel mystery oil. I got it down to where it would tick for a few mins till pumped up. then she finally started to tick again all the time. so now it's cam and lifters.
my .02 is the seafoam. I don't like any other engine cleaner.
good luck.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 04-04-2009, 12:19 AM   #10
kwplot34
All of the above mentioned products will help with sticky lifters,valves,and carbon deposits.
stick the vacuum hose from the PCV in the bottle and let it suck some through the motor. WARNING************* if you live in a community with real close neighbors they will hate you while doing this********
the motor will smoke BADDDDD and put some in the oil at least a QT and leave 1 Qt of oil out,run the motor some and see if it cures the noisy lifters.
Another good trick to clean out a motor is to use a synthetic oil,not a blend but straight synthetic,the down side to this is any all possible oil leaks will leak. just make sure whatever you do to change the oil around 100-200 miles and the filter,because all this carbon and sludge you are knocking loose is clogging the oil filter and may get into the bearings,and then bad things happen.
kwplot34 is offline   Reply With Quote
Old 04-04-2009, 05:14 AM   #11
meansting04
meansting04's Avatar
It could just be a rocker arm that is backed off a little. I would strt it run it to temp and then try and to back each rocker off till it ticks and tighten a half to 3/4 of a turn. This will also help you find the lifter if all of the rockers are right.
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 04-04-2009, 08:40 AM   #12
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Good Thread...I'm going to try this Seafoam stuff.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-04-2009, 04:31 PM   #13
fine69
fine69's Avatar
You substitue quart for quart tranny fluid for oil.
Board member #6
Old 04-04-2009, 04:42 PM   #14
70clone
70clone's Avatar
i always use valve medic from advance auto parts it has worked everytime for me its designed specifically for lifters if it doesnt work then you need new lifters
70clone is offline   Reply With Quote
Old 04-04-2009, 05:11 PM   #15
old Chevy guy
old Chevy guy's Avatar
Take off the valve cover on that side and get a looksee at whats going on in there. I had a 305 in my van that ticked for a long time and then started to pop out of the carb.Thought for sure the cam was bad but decided to look anyway and the pushrod had worn out on the top and made the thing tick then as it got worse the rocker arm feel off then it started poping. My 71 p/u started ticking loud just all of the sudden one day too and was also a pushrod.I think they get plugged up and the rocker starves for oil and they wear out. Also I hate to say it BUT being a 307 a bad cam is always something to consider. How many miles?
old Chevy guy is offline   Reply With Quote
Old 04-04-2009, 10:28 PM   #16
Grapdawg
Driven a 72
Grapdawg's Avatar
Well I adjusted my lifters today with some advise from Longhorn Man, I was able to quiet her down alot, but it still has a mild ticking at higher RPM but that is expected. The odometer reads 13000+ so im assuming she has 213000 miles. Thanks all for the great advise as always.
1996 GMC JIMMY
1972 CHEVY C10 LWB
