Old 04-04-2009, 02:07 AM   #1
69swbman
needing to find some one who has the desk top dyno
wanting to get an estimated guess of what my motor is pushing (hp,tq)
stadard bore 350 with factory flattops (dont know compresson)
565 lift cam hyd roller
hyd roller lifters
2.02 heads (ported and polished) 600" lift springs
performer rpm intake
750 cfm carb (avs thunder series with vacuum secondaries)
if need more info ask me thanks
69swbman is offline   Reply With Quote
Old 04-04-2009, 06:54 AM   #2
weircc
weircc's Avatar
Re: needing to find some one who has the desk top dyno
try this go to comp cams website they have a program kinda like desktop dyno and its free hope this helps.
weircc is offline   Reply With Quote
Old 04-04-2009, 09:59 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
You'll need to know the compression and cam specs to run it on Desktop Dyno.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-09-2009, 11:25 PM   #4
69swbman
here u go sinister
cam specs
rpm range 2500-6000
int exh
valve lash hyd hyd
duration 286 286
duration @ .050" lift 230 230
valve lift 0.56 0.56
lobe lift 0.377 0.377
and 11:1 compresson
Old 04-10-2009, 12:06 AM   #5
bowtieboy93
bowtieboy93's Avatar
If possible
can i know your timing degree, exhaust (headers long or shorty, as well as mufflers y/n) and what heads are you running such as stock high permorfance street, or race
based on what i think you have for those, I have 405 hp @ 5500 RPM
and 412 lb ft @ 4000 rpm
I could get it closer with those specs though
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 04-10-2009, 09:27 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
I have Dyno2003. I would need your cam lobe center angle, intake centerline, and exhaust centerline for the cam.
Edit: looks like bowtieboy93 has got you covered.
Beat it to fit,
Old 04-10-2009, 10:21 AM   #7
69swbman
cam lobe center angle 110
intake centerline 106
exhaust centerline didnt show it
timing degree 0.006
im running long tube headers with 40 series flowmasters
the heads are stock double humps 2.02 valves ported and polished with 600" springs and screw in studs
Old 04-10-2009, 11:19 AM   #8
Sinister
Between Trucks...
Sinister's Avatar
I got 409 HP@5500 RPM
422 ft/lbs torque@4500 RPM
Beat it to fit,
Old 04-10-2009, 11:23 AM   #9
69swbman
thanks sin you wouldnt b able to make me a copy of that desk top dyno could u
Old 04-10-2009, 12:52 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Sorry, not possible. I can only print a copy, and I don't have a printer hooked up to this PC.
Beat it to fit,
Old 04-11-2009, 01:04 AM   #11
69swbman
o well jus wondering if u could i would send u some money for it one more question wut would that b if it had 12:1 compression
Old 04-11-2009, 08:15 AM   #12
Sinister
Between Trucks...
Sinister's Avatar
At 12:1 compression 428 HP @ 5500 RPM
437 ft/lbs torque @ 4500 RPM
Sorry I can't get you a copy of the results, I don't have a printer.
Beat it to fit,
