![]() Join Date: Aug 2008
Exhaust heat riser- need it?
Hey guys,
Here the situation, I have a 69 350 with the stock exhaust manifolds. This truck has ran pretty good as is, however there is a leak at the heat riser that I would like to get rid of. Looking at it, I noticed the riser was rusted/frozen in place, Do I need this? Thanks for your help.
Nothing better than an old truck... 76 C-10 Silverado 92 Silverado Z71 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Exhaust heat riser- need it?
Unless your cold Michigan winters dictate otherwise, toss it. I had one go bad, ran without it for several years, finally installed a new one, no difference at all. After I noticed one muffler rotting out while the other was still good, I removed the heat riser for good. FWIW, my truck is started every day and winter temps typically dip into the teens here -- no difference with or without the heat riser. And they are not cheap either....
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Stocker is right, heat risers are spendy. They are necessary up here only if you're a winter driver. They only help heat up the manifold. They are a driveablity piece more than anything. I'd gut the flapper valve out of it, braze the pivot holes closed & never think of it again.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
![]() Join Date: Jul 2004
Don't need it even in colder temps. As long as the passage under the carb is not plugged, the exhaust will still heat the intake pretty quick.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Thanks Guys,
Ive been driving it all winter on nice days with no problems starting. So i'll fill the holes and put it back. Now to find a manifold for the right side...
