Old 04-04-2009, 07:10 PM   #1
gotmud
gotmud's Avatar
Cool No Fuel...????
I got the beast to crank today....as long as I was spraying starter fluid into the carb. Im using a 64 tank. Not sure if it is different from the stock but the metal fuel line comes out the top and then exists the cab near the bottom of the tank. I put in 2 gal of fresh gas....its been about 4 years since the truck was run. I removed the hoses from the fuel pump and from the metal fuel line under the bottom of the truck and not a drop.
Could this be plugged.... Any ideas on what I need to do to clean it up to it holds gas and will allow gas to be pumped to the engine?
I sounded good with the pipes uncapped!
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 04-04-2009, 08:05 PM   #2
cdowns
cdowns's Avatar
Re: No Fuel...????
2gallons aint much in an empty tank try a few more
Old 04-05-2009, 12:20 AM   #3
OregonC20
OregonC20's Avatar
Re: No Fuel...????
Check your sending unit inside the gas tank. The inside of my gas tank was all rusted and the sending unit was clogged with junk. After I replaced those two my truck run fine.
OregonC20 is offline   Reply With Quote
Old 04-05-2009, 02:45 AM   #4
spinning wheels
spinning wheels's Avatar
Re: No Fuel...????
You have gotten some good advise. Try adding more fuel, at least another 5 gallons.
If that doesn't help, remove the sending unit on the tank. When I replaced mine, it was rusted and almost plugged.
If it still isn't getting fuel, check your fuel pump. It may need replacing, they get weak or just wear out. I have had one on a work truck (toyota), just plain fall apart.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
